Go Back   NastyZ28.com > General Topics > Camaro Questions
Old 06-26-2006, 12:10:34 AM   #1
spicewood1
BANNED
Anybody have a 69 Camaro wiring diagram?
I have a issue with the harness at or near the voltage regulator on my 69 Camaro and need help. I currently have NO wire connected to the #3 marked terminal on the regulator, and I have 2 very large (10 ga) red wires hanging out of the harness at the same area, not connected to anything at all. Can anyone post a diagram, send me the diagram, or tell me where I can find it on the web? Thanks a ton,
Paul
spicewood1 is offline   Reply With Quote
Old 06-26-2006, 05:08:42 PM   #2
spicewood1
BANNED
Anybody? I'd like to go to a cruise-in this Friday and can't go like this.
Paul
Old 06-26-2006, 09:01:11 PM   #3
spoonLT1355
spoonLT1355's Avatar
I answered your other post;
I have one, but can't get it till tomorrow night.
Μολὼν λαβέ
Tip of the Day: Be careful of following the masses - because when you remove the "m", who exactly are you following?
Some of the wiring diagrams that I have,
http://community.webshots.com/user/spoonlt1355
Pics of April's Cobolt gauge set-up:
http://www.cardomain.com/id/spoonlt1355
Tilt steering column rebuild:
http://www.cardomain.com/ride/3223935
spoonLT1355 is offline   Reply With Quote
Old 06-26-2006, 09:02:35 PM   #4
mike73z
its been awile, but I remember that the 69, and 70 where almost identical ( not the A/c stuff) , but all the under the hood stuff. As far as what your looking for it should be the same. http://www.nastyz28.com/camaro/wire/70-engwire.jpg
mike73z is offline   Reply With Quote
Old 06-27-2006, 10:11:15 AM   #5
Eric68
The external regulator on my 68 has been long gone, but as I recall, the large red wire goes to the horn relay which is mounted right below the reg. The big red wire goes to the top lug and is held by a scew.
Here is a link to a diagram that should help. Instructions are for converting from an alternator with an external regulator to one with an internal regulator.
Blue, white, orange, brown is the order of the wires on the flat 4 wire regulator connector from top to bottom. When converting to an internal reg the blue and brown wires get tied together and the center white and orange get disconnected and taped.
http://www.camaros.net/techref/ftecref14.html
E85 Carb Builder and E85 racer
www.horsepowerinnovations.com
68 Camaro with 427" SBC
Current best ET 9.96 @ 133 mph 1.319 sixty foot NA through the mufflers.
Eric68 is offline   Reply With Quote
