Old 06-19-2006, 06:15:33 PM   #1
78LT383
78LT383's Avatar
Underbody paint- what's best?
Hey guys,
I'm stripping the undercoating in order to find and address hidden rust areas, and intend to paint it afterwords. This seems to be effective in new cars (my 2001 Silverado still seems clean underneath, a testament to the improvements in paint in the last 30 years) and this car will never see a winter road again, so I'm thinking paint should be sufficient.
I have found a few areas with pinholes in the floorboards which I intend to reinforce with fiberglass (from the inside) after a thorough wire brushing down to bare metal. The front passenger side will be completely replaced with a toe panel from a donor car and a new patch floor panel. After this, the remaining rust areas will be treated with POR. Finally, I'm planning on coating the inside with spray-in bed liner material.
As for the underside, after all this is done, what's the most durable (black) paint? Suggestions I've received so far were:
  • Implement (tractor) paint
  • Catalyzed acrylic urethane enamel
  • basic lacquer
  • rustoleum
  • spray-in bedliner material (ugly but tough)
What results have you guys had? Do you have a favorite? What other suggestions do you have?
I'll get this thing put back together eventually!
78LT383 is offline   Reply With Quote
Old 06-19-2006, 10:34:45 PM   #2
rustover
rustover's Avatar
I am working toward this on my 81, so I 'm looking forward to some of the responses. I am leaning toward an epoxy primer, Maybe ppg's DP90.
Also I am a big fan of Eastwoods chassis black. They now offer it in different levels of gloss. They also now have a chassis black primer. I bought these new products for some of my suspension parts. Maybe I can have some pics by the end of the week. I used the original Eastwood chassis black on my 72 and its nice.
I also have some pinholes in my floor. I was going to try to mig them up instead of the fiberglass. Not sure if it will burn through or not.
Russ:
Romans 10:9
Project Thread:
http://www.nastyz28.com/forum/showthread.php?t=270387
rustover is offline   Reply With Quote
Old 06-20-2006, 10:59:38 AM   #3
Shane
Shane's Avatar
The DP90 is the way to go. If your car came from Norwood, then the red-oxide from PPG is excellent too (DP74). The DP74 and DP90 are pretty close to the same thing - just a different color.
Shane is offline   Reply With Quote
Old 06-22-2006, 04:52:17 PM   #4
78LT383
78LT383's Avatar
Are these sealers or topcoats?
Old 06-22-2006, 05:57:40 PM   #5
Chevynut67
You might want to consider this stuff instead of undercoating:
http://lizardskin.com/
Chevynut67 is offline   Reply With Quote
Old 06-22-2006, 06:18:22 PM   #6
Toomanyhobbys
Toomanyhobbys's Avatar
Are these applied by rattle can? How is the Dimple stuff by Rustoleom?
RATDOG RACING
Marks71BB ---
remember, ya dont have to own a second gen to hang with us
Toomanyhobbys is offline   Reply With Quote
Old 06-22-2006, 11:16:51 PM   #7
78LT383
78LT383's Avatar
Chevynut67, it looks like that stuff might be porous (water resistant), but it is paintable so it might be an option. I'll have to check on that.
Toomanyhobbys (boy I can identify with that!!!) I'm not familiar with the dimple stuff. Who carries it in stock? Is it at Wal-Mart or other basic stores?
Old 06-23-2006, 10:47:56 AM   #8
Toomanyhobbys
78LT Home Dump carrys the stuff. Neighbor did his truck tool boxes with the stuff. Looks good.
RATDOG RACING
Marks71BB ---
Old 06-27-2006, 07:10:09 AM   #9
niko14
does an asphalt undercoating is great to shoot the undercarriage?
Pedal to the metal
http://www.cardomain.com/ride/2159563
niko14 is offline   Reply With Quote
Old 06-27-2006, 08:04:50 AM   #10
78LT383
78LT383's Avatar
It seems to have been very effective as a preservative, but there were a few places on my car where (after 30 years) it had started to lose its grip on the steel, or else the GM sealer had lost its grip and the undercoating fell away with the sealer. Either way, it had formed a pocket for moisture to collect and stay in.
Asphault undercoating takes a special heated sprayer for application (this is NOT the same thing as "rubberized undercoating" available at the auto parts store) but places like Ziebart and dealerships usually have this equipment.
Old 06-28-2006, 07:18:55 PM   #11
niko14
I shoot a little part of my undercarriage with asphalt undercoating to see what it look like and it look nice:
i know its not perfect i dont have finish i just shoot it fast...do you think it will do a great job or i must try another product??
here is my product:
http://www.dominionsureseal.com/prod...id=92&catid=31
Pedal to the metal
