Go Back   NastyZ28.com > General Topics > Troubleshooting & Diagnosis
Old 05-28-2006, 08:15:12 PM   #1
jayb53guy
jayb53guy's Avatar
Help, won't start
went to autozone of all places and the camaro died. I thought it was the positive cable at first swapped it, no luck. The battery is charged, everything is working as advertised, but when I turn the key, nothing. I mean, nothing. No clicks, no vibes, no nothing. All the lights work, radio...etc. I swapped out the starter and solenoid, and no luck there either. I thought maybe the starter was locked up, but that wasn't it.
Anyone have a suggestion? I have a bad feeling I am going to be shooting wires, oh what fun..
Ask not what your country can do for you, but what can you do for your country.
jayb53guy is offline   Reply With Quote
Old 05-29-2006, 02:52:07 AM   #2
Cardinal
Sounds like neutral safety circuit to me. Check with a test light or volt meter for voltage when you hit the start position on the ignition key. If memory serves me right, it's the purple wire on the starter that goes to the "S" side of the solenoid.
Cardinal
Cardinal is offline   Reply With Quote
Old 05-29-2006, 08:11:56 AM   #3
jayb53guy
jayb53guy's Avatar
Pretty strange how I have 12.5V at the battery, but when I put the meter down to the same wire on the solenoid I get like 1.7V....I think that neutral safety switch may be my culprit...I hope anyway.
Thanks.
Old 05-29-2006, 08:50:07 AM   #4
Cardinal
Check all of the grounds too. Had a fist fight with 68 Camaro that did the same thing you're fighting. Turned out that the ground strap from the firewall to the engine valve cover bott was loose.
Cardinal
Old 05-29-2006, 09:01:59 AM   #5
jayb53guy
jayb53guy's Avatar
Just tried jumpering the purple & purple/white wires and still had nothing. I thought jumpering those would eliminate the neutral switch. I may run a ground just to eliminate it...Thanks!
Old 05-29-2006, 11:02:10 AM   #6
jayb53guy
jayb53guy's Avatar
I got nothing. This blows.
Time to start shooting wires.
Old 05-29-2006, 11:29:28 AM   #7
Scooby
Thanks.
Are you talking about the positive lead to the starter from the battery? If so then that's your problem. Also, checked the inline fuse on the starter lead.
Scooby is offline   Reply With Quote
Old 05-29-2006, 01:50:36 PM   #8
jayb53guy
jayb53guy's Avatar
Its a brand new wire. It was the first thing I changed. Its been a long day, and its getting longer...
Old 05-29-2006, 02:34:14 PM   #9
COPO's Avatar
At least it's not raining or snowing.
Mark My 70 Z28 Web Site http://www.nastyz28.com/~copo/index.htm
Twitter
Qjet rebuilt etc http://www.nastyz28.com/~copo/qjet.zip
COPO is online now   Reply With Quote
Old 05-29-2006, 02:49:08 PM   #10
Scooby
still shouldn't have a voltage drop on the that lead from the battery to the starter. May have a slight drop but not from 12.5 to 1.7 maybe 12.3 or so.. netural safety switch has nothing to do with that lead
Old 05-29-2006, 03:00:27 PM   #11
jayb53guy
jayb53guy's Avatar
I have checked it with the key in every position. Using the same ground, battery terminal 12.5, the post on the solenoid 0.
Just for grins i hooked a set of jumper cables up to my battery and tapped the old starter, it spun like it was new. WTF? This is ridiculous. How do you lose voltage in a 32" piece of wire?
Old 05-29-2006, 03:01:12 PM   #12
jayb53guy
jayb53guy's Avatar
I have a garage, and another car....
Old 05-29-2006, 07:35:11 PM   #13
Qwik75LT
I had the same problem on my 75. Turned out to be the starter switch on the column under the dash.
John
Qwik75LT is offline   Reply With Quote
Old 05-29-2006, 08:12:01 PM   #14
1owner72
I had a problem like that on my Pontiac. Turned out the rebuilt starter was also faulty even though it worked on the bench. Put a load on it and nothing happened. Check again to make sure your starters are good.
1owner72 is offline   Reply With Quote
Old 05-29-2006, 09:41:32 PM   #15
GoldenOne7710
Have you tried to see if it would start an ANY of the gears? I've seen the linkage get screwed up for no apperent reason. Turn the key all the way over like you're gonna start it, then simply move the gear stick through all the gears and see if anything "clicks" then.
-Andy
1979 Z/28 (better than cloned)
ΜOΛΩΝ ΛΑΒE
Proud NRA Lifetime Member
GeorgiaCarry.org Member
GeorgiaPacking.org Member
GoldenOne7710 is online now   Reply With Quote
