The turn signals don't work at all or the indicator don't work?? Two completly different circuits so it makes a differece. The backlighting lights are all in parallel, that means the others will still work even if some are removed or burned out. The blinkers share the ground side of a circuit with backlights. Since neither of them work I am guessing that is most likely your problem. When you installed tach yhou said you had to take out two lights, but on the back of the cluster behing the tach there are three studes that stick out and have nuts on them, these nuts hold the circuit board to the large metal plate behind the tach, this is you common ground for just about everything back there, I am guessing that you either didn't hook one up or it is dirty underneath and not making good contact, or maybe in the process one of the runs on the circuit got broke, look at the back close and follow the lines around, look for any breaks, if it has any I can tell you how to repair pretty easy.
