Neutral Safety Switch
If I pull the connectors out of the neutral safety switch and run a wire from green wire to green wire and a wire from purple wire to purple wire, then it should technically activate both the safety start feature and the backup lights once I turn the key?
Dave
1973
350 SB, Holley 770, Air Gap, HEI
M-22 Special Wide Ratio 4-Speed
3.73 Posi Rear, Hotchkis Suspension
Naked Lady Shift Knob
"You ought to ditch the two geeks you're in the car with now and get in with us..."
