Old 05-10-2006, 11:04:52 PM   #1
Javelin3o4
Javelin3o4's Avatar
Installing Engine/Trans together..
Im curious as to what you guys think about dropping the engine and trans in as 1 unit? currently I have no engine installed but there is a 3 speed still mounted in. I plan on removing the 3 speed and installing my TH350 that i have a shift kit in, along with my new GM 350 crate engine. What im wondering about is possibly using one of those lifting plates you mount to the manifold and connect your cherry picker from there. The engine has a edelbrock intake everything else is stock. Is this too much weight or am i better off just bolting to the block. Im getting one of those setups for the hoist that allow you to change the angle as you manuever the engine into position.
The main reason i want to do it as one unit is I may be doing this by myself, and dont want to deal with trying to install a trans from underneither and fuss with lining it up with the dowels on the block. What do you guys suggest?
Javelin3o4 is online now   Reply With Quote
Old 05-10-2006, 11:16:56 PM   #2
Badkarma
Badkarma's Avatar
its the only way to fly. I did the same thing as have many others here on the board. Only diffrence is that I used chains bolted to the front and back of each head and one of those load levelers to get it all lined up. Saves you the trouble of having to crawl under the car and get it all lined up and bolted together.
*used to have*
72 RS, ZZ383- Pro Systems 780 DP, HVH "Super sucker" carbspacer and RPM Airgap manifold,Ron Davis radiator, flowmaster american thunder system modified with two 40 series mufflers, pro-billet distributer,6AL box, msd super conducter plug wires, MSD APS 160 amp alternator and March serpantine conversion.
Current toy
2006 Silverado SS
!!!Piss on C.A.R.B.!!!
Badkarma is offline   Reply With Quote
Old 05-10-2006, 11:50:31 PM   #3
gregh
gregh's Avatar
I used to always do them seperately but my last 3 times(all this winter/spring, don't ask) I've done them as a pair & now I'm convinced it is easier.
I just used a chain from the front of one head to the other(intake not on) & with my wife running the hoist, everything was settled in place within 10 minutes.
10.236@131.52mph with a 150 shot & 11.60@118mph NA
A 10 second street car, eh!
SBC 409, through the mufflers, on DOT radials, you know, like a street car should be.
gregh is offline   Reply With Quote
Old 05-11-2006, 12:38:40 AM   #4
79silverz28
Just did exact thing...no problem.
I just installed a 350 engine, Turbo 350 tranny bolted together. Used the bracket on top, bolted to carb holes. Took me and my friend about 30 minutes. Just go slowly and it will go in. No chains, but they do help a lot if you can get a hold of them.
I don't know if this makes any difference or not, but I did remove the hood, and pull the headers out of the way to help give me plenty of room.
79silverz28 is offline   Reply With Quote
Old 05-11-2006, 04:52:31 AM   #5
Cardinal
Together again. Much better together as less likely to ruin the pump not having the converter seated. With a manual, unless you like lifting (in my younger days I cycled a T10 in and out four times in one day trying to find a clutch problem), installed is the only way to fly.
Cardinal
Cardinal is offline   Reply With Quote
Old 05-11-2006, 09:06:36 AM   #6
Ztoy
Ztoy's Avatar
a BIG amen to installing them together....whew! those trannys get heavy laying onb your back doing a bench press with a big hvy tranny!
And those levelers are the ONLY way to go about it as well.....
I'm just Mike
“From the hour the Pilgrims landed, to the present day, events, occurrences, and tendencies prove that to insure peace, security and happiness, the rifle and pistol are equally indispensable . . . the very atmosphere of firearms everywhere restrains evil interference - they deserve a place of honor with all that is good”
George Washington
Ztoy is offline   Reply With Quote
Old 05-11-2006, 10:47:43 AM   #7
Twisted_Metal's Avatar
If you are replacing/rebuilding the engine or engine AND tranny... pull them together. (Hood off and front of car raised, rear wheels blocked.)
If you are replacing/rebuilding only the tranny... leave the engine in place and drop the tranny from below.
Old 05-11-2006, 11:18:59 AM   #8
Trainman
Location: Illinois (beautiful weather at least 20 days a year)
Beg, borrow or steal (JK!) an engine leveler. There is NO other way to fly if you are installing an engine and trans together. Cuts the job time in half in my opinion.
http://www.northerntool.com/webapp/w...70_19979_19979
____________________________________
In the war between ingenius and ungenius chalk up another victory for the later.
Trainman is offline   Reply With Quote
Old 05-11-2006, 11:50:35 AM   #9
calereeves
Haha...love the fake engine in the northern tool pic!
Faster til the thrill of speed overcomes the fear of death.
calereeves is offline   Reply With Quote
Old 05-11-2006, 01:11:42 PM   #10
cam80
BINGO!! That's what I have typically done in the past. Much easier!
That government is best which governs the least, because its people discipline themselves. --Thomas Jefferson
A government big enough to give you everything you want is a government big enough to take from you everything you have.--Gerald Ford
"When one gets in bed with government, one must expect the diseases it spreads." --Congressman Ron Paul M.D.
cam80 is offline   Reply With Quote
Old 05-11-2006, 01:57:34 PM   #11
theflash
theflash's Avatar
I would think that on a camaro you might have clearance issues bolting a chain to the heads (esp the rear), but I tell you those load levelers are worth their weight in gold.
theflash is online now   Reply With Quote
Old 05-11-2006, 08:12:49 PM   #12
cmonson
cmonson's Avatar
it is no problem, i've done it twice with my tranny already bolted on... I have a 4 speed but it should work the same. I have always bolted up my tranny first to align the clutch. It slides in easy.
I had a 2x4 on the floor board to help protect it. You'll see what I mean when you try
cmonson is offline   Reply With Quote
Old 05-11-2006, 10:42:49 PM   #13
calereeves
The last couple of times I had mine out, I pulled the hood, fenders, disconnected the front brake lines, and pulled the whole front subframe off. Had everything off and out in about 45 mintues. Extremely easy to work on stuff, and its a great time to clean up the engine bay and whatnot.
Old 05-11-2006, 10:45:58 PM   #14
cmonson
cmonson's Avatar
yes I wish I would have done that to mine... Too late now until an engine refresh...
Old 05-11-2006, 11:33:29 PM   #15
Javelin3o4
Javelin3o4's Avatar
the hoods already off cause i sandblasted teh engine compartment and painted it, i just have to remove the 3 speed, get teh correct motor mounts then i can drop it in. Summit i think had the level for like 50 bucks or something.
i was just worried that weight issue and using a carb plate. I think i still may have the lift brackets that came on the engine when i first got it.
So what do you guys suggest chains on each corner of the block or a carb plate?
