Go Back   NastyZ28.com > Body & Chassis Restoration > Interior Restoration
Old 10-26-2003, 04:43:00 PM   #1
BurningLime71307
Thinking about taking out my dash out at somepoint
Just wanted to clean sh*t out,make everything organized.Anyone do this before?Any tips to help?Thanks.
How come my MR2 has to attract the rice crowd?
BurningLime71307 is offline   Reply With Quote
Old 10-26-2003, 05:00:00 PM   #2
HCKY23
It's just a very tedious job. Save your back and remove both front seats first, then the center console. It makes crawling under the dash so much easier. Disconnect the battery. Then remove the lower dash plastic. You'll need to disconnect the vents from the flex hoses. That should make it easier to unplug everything on the gauge cluster. Remove the gauge cluster. I would leave the dash pad in place, or else you need to disconnect a lot of crap. You should now have access to all the wiring and ducts to tidy it up. Just leave enough slack on the wires so you can plug the gauges back in before you fasten the cluster to the pad. I just did this myself. Aftet I tied the wires neatly, I uncased them in pieces of that split plastic tubing. It keeps them neat and gives added protection against rubbing on sharp edges of metal under the dash.
btw, where in NY are you. I'm on LI.
Steve. 74 orig owner
383, Comp 280, Sportsman II, HD TH350, 3:42 posi, 4wdisc, 12:1 box, IAS, headers, true-dual w/H-pipe. All new susp/bushings.
Long Island Phantom Hockey -23-
Steve. 74 Sport Coupe,orig owner
383, Comp 280, Sportsman II, HD TH350, 3:42 posi, 4wdisc, 12:1 IROC box, IAS, headers, duals w/H-pipe. All new susp/bushings.
HCKY23 is offline   Reply With Quote
Old 10-26-2003, 05:07:00 PM   #3
BurningLime71307
Thanks.Nothing very hard about mixing up wires or not?I live in St.Lawrence County.
Murder the Ricer...
Every 2nd Gen. Owners favorite game.
