Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Old 02-20-2006, 12:17:25 PM   #1
ttopbandit
ttopbandit's Avatar
Question VOLTMETER vs AMMETER
I was offered a free set of guages, only problem is that the guages have a ammeter instead of a voltmeter. Now, I know what kinda volts a healthy alt puts out, but how should I read this AMMETER? I've always had a voltmeter, so this is new to me. What should be the normal reading? I have a one wire set-up, if that matters at all.
ttopbandit is offline   Reply With Quote
Old 02-20-2006, 12:57:39 PM   #2
Gary S
Factory GM ammeters are useless. As long as everything is working right, you probably will never see it fluctuate more than a needles-width either way. You need an almost dead battery to make the needle move, and you don't ever want to get to that point.
If possible, get a voltmeter to replace the ammeter before you instlall it.
Gary S is online now   Reply With Quote
Old 02-20-2006, 01:06:51 PM   #3
ttopbandit
ttopbandit's Avatar
It is a brand new autoguage set.
Old 02-20-2006, 01:25:12 PM   #4
Mayhem74
Generally the go from -40 to +40. You want it to be in the middle. - Means the alternator is going out, and youre running off the battery. When you start it or if you have a really big stereo youll make the needle go into the positive, which means the alternator is charging the battery.
Mayhem74 is offline   Reply With Quote
Old 02-20-2006, 02:07:58 PM   #5
Gary S
The aftermarket ammeter gauges read better because they are true ammeter gauges. That leads to a brand new set of problems. True ammeters have to be wired in series with the alternator charge line, so that means you have to splice into the large (usually #10) wire from the alternator to the battery and extend it with more #10 or #8 heavy wire all the way from the alternator to the interior of the car to one side of the ammeter, and from there back to the battery. Your charging current has to pass through this entire long distance circuit, and if you happen to short that wire in the future, expect lots of fire and smoke. This is why GM used a fake ammeter that really is a differential voltmeter that measures minute voltage drops between two points on the charge circuit. With the factory one, the charging current doesn't flow through the GM ammeters.
If possible, try to find a voltmeter, or simply forget about wiring up the ammeter. A voltmeter can simply be connected to the +12 at the fuse panel and ground. They are much simpler and work better.
Old 02-20-2006, 06:55:51 PM   #6
ttopbandit
ttopbandit's Avatar
Thanks, will do.
Old 02-23-2006, 02:11:38 PM   #7
undee72z
If anything besides the starter is wired to the battery, the ampmeter will show the batterys charge rate plus the draw from any accessories wired to it.
Has to be wired in series with the battery charge wire, if wired in series with the alternator output wire it will show all alternator output, which can be much more than the ampmeter can handle.
Best advice here, a voltmeter also gives more info on what the charging system is doing. Which is better for monitoring a vehicle's electrical system - a Voltmeter or an Ammeter?
My 72Z
undee72z is offline   Reply With Quote
Old 02-23-2006, 02:22:01 PM   #8
jforb
I kind of like the idiot light, especially with the 73-up internal regulator alternators, which work for years and years without any trouble. And it's not likely that you'll find a weak battery with a voltmeter any sooner than you would without one.
I never even look at the voltmeters in our late model cars.
Jim
jforb is offline   Reply With Quote
