Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Old 02-08-2006, 11:23:16 AM   #1
REDDEVIL
REDDEVIL's Avatar
Aternator shut-off fuse?
I don't know if anyone saw the post in the BS section yesterday, but the Camaro almost went up in flames. I have a Flaming River electrical and alternator shut-off. The wires to the alternator came loose under the car, sat on the exhaust, and got toasted all the way back to the source. Damaged the trunk, but not bad. Anyways, is there any way to fuse/switch wiring to an alternator and still be legal at the track? Or does the current fluctuate too much. I don't want to remove the wires, they are necessary to race. But I want piece of mind that this won't happen again or worse.
My F-Body Page: http://www.freewebs.com/fbodyreddevil/
70 RS/SS 396: 470 RWHP, 454, Merlin heads, TRW forged pistons, dual quads, TH400, 4.10's
79 T/A: 403, forged pistons, TH350, 3.73's
79 Z28: Factory correct, Borg-Warner T-10, 3.73's
96 WS6: #941, 4L60E
99 SS: SLP#284, T-56
REDDEVIL is offline   Reply With Quote
Old 02-08-2006, 12:07:20 PM   #2
BonzoHansen
LGM, Admin
BonzoHansen's Avatar
I think you should call mad electric. Check out http://www.madelectrical.com/catalog/tm-1.shtml
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Originally Posted by big gear head
Just remember, if you can't afford to do it right the first time then you can't afford to fix it the second time.
Where's that confounded bridge?
BonzoHansen is offline   Reply With Quote
Old 02-08-2006, 10:00:35 PM   #3
sniggle_t
sniggle_t's Avatar
I'll second Mad Electrical. Mark really knows his stuff and is willing to talk to you about your individual electrical needs. His products are top notch in my book.
I recently attended a sexual harassment seminar,
now I think I'll be really good at it!
NASCAR - Non Athletic Sport Centered Around Rednecks
Going to war over religon - "Basically it's killing each other to see who has the best imaginary friend"
sniggle_t is offline   Reply With Quote
Old 02-10-2006, 09:44:21 PM   #4
1974typelt/z28
Wire as previously posted but run the 8ga wire inside the car though the trough(sp) under the sill plates and put it in convoluted tubing.
1974typelt/z28 is offline   Reply With Quote
Old 02-10-2006, 11:25:35 PM   #5
jforb
And put a fusible link in it too.
Jim
jforb is offline   Reply With Quote
Old 02-11-2006, 08:48:38 AM   #6
BonzoHansen
LGM, Admin
Yup. The pic above shows a 12 ga link right at the battery side of the solenoid.
