02-04-2006, 12:41:06 AM
#1
whats the torque spects on the intake
im swaping my intake can any one tell me the torque spects and order ty
02-04-2006, 12:41:49 AM
#2
oh yeah the engine is a 350
02-04-2006, 10:08:46 AM
#3
Chiltons says 30 lb*ft on the bolts.
The pattern starts with the center pair of bolts on each side - do the rear one of that pair, then the rear one of that pair on the other side. Next the front two of the center pairs, and keep working in a spiral pattern outwards. Hope that makes sense.
I also usually do it in two stages just to make sure everything is torqued evenly and is flat - one pass at 15 lb*ft, then a second at 30.
Finally graduated school and working for GM!
'77 Camaro Z/28 'Original' - mild 357 with home-ported heads/intake, Q-jet, 4-sp, 3.42's. 12" discs, D61 pads, SC&C upper arms, 600#/175# springs, rear discs waiting
'70 Cadillac Deville: 10:1 472ci, black leather and everything power/automatic
'71 Mercedes 220D: 2.2L diesel 4sp
'74 Fiat Spider: 1.8L, 5-sp
'92 LeBaron LX: 3.0L 5sp
02-04-2006, 03:04:49 PM
#4
cool i thought it was somthing like that but wasent sure ty
02-04-2006, 05:25:56 PM
#5
BANNED
Hey, I thought I hear sometime in the past you torque the aftermarket aluminum intakes less than the factory cast because the pressure could crack it??
02-05-2006, 05:34:39 PM
#6
could someone check this i am putting on an aftermarket one like a performer type
02-05-2006, 06:07:52 PM
#7
Intake doesn't matter....if it's an SBC then the torque specs are 30 lbs./ft.
Torque in 2 or 3 stages, then check every week cause heat/cold cycles will relax the gasket.
1978 Camaro LT: 406, TFS heads (for now), mild hyd. roller, headers, ZZ4 intake, Qjet, TH350 with mild 2000 or so stall (aaargh!), 3.42 posi.
In the works: different heads, more stall lol, more cam, that's about it til painting season rolls around
Don't stop believin'
Hold on to that feelin'
02-06-2006, 12:24:42 AM
#8
ok then
02-06-2006, 10:25:20 AM
#9
What about the 4 center bolts? How do you meassure their torque?
It's near impossible to get to them with anything else than a standard forkwrench.
I recently installed a Edelbrock Performer, but I tightened the bolts to the point where they felt tight, but not overlytight. Offcourse I did tighten them in the order they should be, starting with the center ones.
| Thread Tools |
| Display Modes |
Linear Mode
