HEI problems
Car still aint starting. getting a blue white spark at plugs, but no juice to fire it seems like. plenty of fuel. TDC every time i redo the dizzy. its a convert to HEI, its getting 12volts, how do i check the dizzy itself. bought it off of a member who said it was limited use, well the plunger and rotor where worn so i dont know if i can believe. how would i go back to my old points just to see if it starts. run a 12 volt to coil, ground coil and run that to dist? or run a wire from big ter on starter to r terminal, then r terminal to coil? beats me but a good HEI at store is 200, and i am running out of cash. it
