12-08-2005, 05:21:32 PM
#1
Ok, 0.0 decked. Domed pistons. What's my compression?
Ok, after that last post about my block being 0 decked I need to refigure what my actual comp ratio is.
Block is 0 decked. .041" head gaskets. 72CC heads. .100" dome on top of pistons with valve reliefs. 4.030" bore.
None of the calculators will let me have a 0 decked block and 0cc's of space downbore.
I've always guessed somewhere close to 10.5:1.
Mine
1971 RS/SS, 355ci SBC, 426hp/423ft.lbs, Bought her when I was 13... Spent every penny I ever saved on her. 1979 Z28, less than 90k original miles, 1974 Corvette Replacement motor, absolutely rust free!
Dads
1970 Z28, Classic Copper, LT1/TH400, My birthday present to him for his 61st Bday, "Happy birthday dad! Now fix it."
12-08-2005, 05:36:24 PM
#2
You didnt give your stroke or gasket bore but if your using a 3.48 crank, my calculator puts you around 10.1
12-08-2005, 05:48:20 PM
#3
Yep, 3.48 crank and unsure of bore.
Mine
Dads
12-08-2005, 10:20:44 PM
#4
So which is it?
What brand/model of pistons are in it? This will give you a more exact static compression ratio calculation.
12-08-2005, 11:04:35 PM
#5
Mine
Dads
12-08-2005, 11:15:08 PM
#6
Unsure of the gasket bore!
Mine
Dads
12-09-2005, 12:18:57 AM
#7
Oops, missed that part. LOL!
Most 350 gaskets are 4.166" bores. But they are not round. What brand/model head gaskets do you run?
12-09-2005, 12:30:21 AM
#8
Felpro premium blue gaskets.
Mine
Dads
12-09-2005, 02:30:43 PM
#9
I would say your right around 10.1:1 Are your heads iron or aluminium?
12-09-2005, 03:56:22 PM
#10
Iron 72CC Goodwrench bowtie heads.
Hmm. Maybe that's why no one can duplicate my build around here. Because I never knew that it was zero decked.
Full specs are:
Eagle Forged crank.
Eagle H-beam rods.
Crane H-302 cam. (Used to be called 3/4 Race Cam)
Keith Black dome top pistons (10-10.5:1)
Block bored .030, zero decked, align honed, balanced and blue printed.
GM Goodwrench aftermarket heads, ported (75%) and polished.
Proform roller rockers.
Weiand high rise, single plane (high RPM) intake.
Holley 780 single pumper.
Engine setup dyno'd at over 400hp and over 400ft/lbs of torque!
Now I know why! lol
Thank you, thank you. I know I'm good.
Really most of it was my machinest. He builds race only motors, so that's mostly why his work is so good.
Mine
Dads
12-09-2005, 03:57:12 PM
#11
Go look up the part number at http://store.summitracing.com for your head gasket. They list all the felpros with a compressed thickness and volume.
For instance, the Felpro Permatorque MLS for the 350 has 8.7cc with a .039" compressed height.
http://store.summitracing.com/partde...autoview=s ku
The Felpro 1003 with a .041" compressed height has a 9.1cc volume.
Also, it appears that most 350 head gaskets from Felpro have a 4.125" bore.
12-09-2005, 04:24:58 PM
#12
It was a trick flow set with Fel Pro Blue stripe gaskets.
I can't find the number for the head gaskets on the box.
But I'm pretty sure I remember them saying .041 on the gaskets themselves.
Mine
Dads
12-09-2005, 05:33:18 PM
#13
You may want to confirm this with an expert, but thats a lot of compression for iron heads. That is unless you plan to use racing gas. If so, thats a killer engine.
12-09-2005, 05:55:04 PM
#14
8 Cyl Engine Bore (in.)4.030 Your Engine Displacement is:355.12 Engine Stroke (in.)3.480 Piston Deck Height (in.)0.000 Your Piston-to-Head clearance is (in.):0.041 head gasket Head Gasket Vol (cc)10.0 Your Head Gasket Volume. is (ci.):0.610Combustion Chamber Vol. (cc)72 Your Deck Clearance Volume is (ci.):0.000 Piston valve reliefs (cc) 0 Your Comb. Chamber Volume is (ci.):4.394 - Your Piston relief/dome Volume is (ci.):0.000 Total single cylinder volume is (ci):49.394 Total single cyl. compression vol is (ci):5.004 Your Compression Ratio is: 9.87:1
my .125 domes worked out to +1.5cc after cc'ing so im guessing yours even out to 0.
I run 93 octane with 62.5cc Iron heads.
old 72 - now driving a third gen
12-10-2005, 03:22:00 PM
#15
Does anyone know a link to where I can download a compression ratio calculator or use one online?
| Thread Tools |
| Display Modes |
Linear Mode
