Old 10-29-2013, 02:20:31 PM   #1
JONESYFXR
Chris Alston's G connectors
I am FINALLY at the point of re-assembly for my 79. I was going to make my own frame ties, then stumbled onto this....
https://www.cachassisworks.com/p-160...-subframe.aspx
I am thinking this would be a nice platform to build my cage off of. What do you guys think?
Thanks in advance.
1979 Camaro-soon to have a 500+ci BBC, turbo 400 with brake and a Moser 40 spline hand built 9 inch
1985 Iroc Z-All original, never seen winter 69K
2008 GMC Sierra 1500
1991 Harley Davidson FXR-Built by yours truly
JONESYFXR is offline   Reply With Quote
Old 10-29-2013, 02:55:06 PM   #2
CamarosRus
I'm thinking that if you (or your fabricator/shop) is going to build a cage
I would want weld in sub frame connector that has stub piece welded into
inner rocker area that main cage hoop welds too..........etc etc
Chuck Sharin
Seattle(area)
CamarosRus@Gmail.com
70 R/S Z-28, 70 SS L-78, 70 R/S SS L-48 (all 4spds)
69 COPO "Recreation"
CamarosRus is offline   Reply With Quote
Old 10-29-2013, 08:38:08 PM   #3
dcart1
Very nice.
dcart1 is offline   Reply With Quote
Old 10-29-2013, 10:02:49 PM   #4
79T/Aman
Site Sponsor
79T/Aman's Avatar
nice piece but I would like to see one installed and what about ground clearance, exhaust routing, you still need solid body bushings.
For that money you could have our roll bar and sub-frame connectors.
Manufacturer of The original GT suspension kits, frame connectors, modular roll bars. www.pro-touringf-body.com
79T/Aman is offline   Reply With Quote
Old 10-29-2013, 10:06:11 PM   #5
79T/Aman
Site Sponsor
79T/Aman's Avatar
if you are going to build a cage you are better off installing "cut in" frame connectors anyway, going up will be more beneficial.
Old 10-30-2013, 09:26:11 AM   #6
JONESYFXR
I'm going to be doing a roll bar with dog legs off the front subframe to the inner rockers. If I were to install the Alston kit, it would be welded in anyway. Here's a link to my build thread and you can see where I'm at and what I'm thinking........
http://www.nastyz28.com/forum/showthread.php?t=166828
This is gonna be a street legal drag car with an 8 point cage. I suspect I will be able to run mid 6's in the 1/8 when all is said and done. I'm hoping I can get on this thing so I will actually be able to drive it this spring.
Any help would be greatly appreciated. Thanks!
