Go Back   NastyZ28.com > Drivetrain & Performance > Competition Camaros
Old 10-19-2005, 12:33:00 AM   #1
pan evac on circle track motors
will this set up work on a circle track motor. i know on drag race motors it helps push the rings against the cylinders for better ring seal.
425HP 350sbc old school build-up
restification in progress 70's baldwin motion NHRA gasser with old school day2 parts
if it's to loud your to old
muscl car is offline   Reply With Quote
Old 10-19-2005, 06:22:00 AM   #2
79T/Aman
Site Sponsor
should work fine as long as the pump holds up to long periods of time at hi rpm and you would have to check how much oil it pulls out of the engine so that it does not fill up the vent tank.
frame connectors, roll bars, suspension, engine parts www.pro-touringf-body.com
79T/Aman is offline   Reply With Quote
Old 10-20-2005, 09:37:00 PM   #3
70 Z UC
Usually if your going to go through all that, you would just use a Dry sump system. It will work better and the bearings are much happier. You can get used 4 stage pumps from the Sprint swaps, for around $300 and the tanks go for $40-80. Just make sure to pull the pump apart & look for damage. Buy from the top runners, they usually get rid of everything yearly.
70 SS Camaro. Bought new by my uncle in 69. I bought it from him in 95, frame off resto in the works.
07 Duramax (11.80 @ 115.849 1.623 60') Stock motor, stock single CP3 (injection pump), SCV trans, MPI twins, 30% injectors, EFI Live tuning, 33x12.5-17 Baja MTZ's 7,640lbs
http://www.youtube.com/watch?v=PdCIK_GtVe8
70 Z UC is offline   Reply With Quote
Old 10-20-2005, 11:24:00 PM   #4
<font face="Arial,Verdana" size="2">Originally posted by 70 Z UC:
Usually if your going to go through all that, you would just use a Dry sump system. It will work better and the bearings are much happier. You can get used 4 stage pumps from the Sprint swaps, for around $300 and the tanks go for $40-80. Just make sure to pull the pump apart & look for damage. Buy from the top runners, they usually get rid of everything yearly.</font>
this is for out dirt track dwarf car with a yamaha R1
