Old 11-19-2012, 12:28:34 PM   #1
DW Holeshot
79 clutch fork return spring ?
Hi guys
Ive only posted a couple times, but have been learning alot about my old bucket of bolts for about a year an a half on here.
Im building a ground up pretty nice car, handling , driver in summer, and locals shows, maybe a track day or two
It was roach when I got it and was missing the clutch fork return spring with the adjuster tightened up against the throw out bearing so it would not fall off
I just installed a new 383 and 5 speed, and want to stay with original Z bar linckage, and I have all new parts installed from NPD.
I can make a return spring bracket if I have to, but can anyone tell me where the original fork return spring connects to the frame to keep it in a straight line pull. Seems Im missing the bracket the spring connects to.
Anyone have a picture of this bracket bolted to the frame ?
Thanks Dale Walker @
Holeshot Performance, the motorcyle guy
DW Holeshot is offline   Reply With Quote
Old 11-19-2012, 12:39:51 PM   #2
nonstopgo68
I just converted my 79Z to a 4 speed and had the same problem.
I read on here that there is a hole on the subframe right next to the motor mount where it can go. Not sure if its supposed to go there cause I couldnt get it there. I wound up putting mine in a hole on the frame between the z-bar and upper control arm to keep it away form the stock exust manifold. Its kinda off to the side but it works. Im not home but if its still not resolved by tonight ill get some pics.
"What we got here is Failure to Communicate"
1979 Z28 350 B/W S T-10
My project progress- http://www.nastyz28.com/forum/showthread.php?t=236922
nonstopgo68 is offline   Reply With Quote
Old 11-19-2012, 12:58:14 PM   #3
Protour-Camaro
There is no bracket or straight line connection for the spring. It connects to the small hole on top of the driver side sub-frame. It will be at a slight angle, If you have the correct spring, it works like a charm.
Protour-Camaro is offline   Reply With Quote
Old 11-19-2012, 01:02:20 PM   #4
nonstopgo68
I have the spring ground -up sent me. Granted it may be wrong, but it didnt work.
Old 11-19-2012, 01:16:43 PM   #5
DW Holeshot
Ok thank you guys, I know this is a simple dumb qusetion. Im pretty sure the kit I have did come with the correct spring, its a real long one. Sure is Mickey Mouse how Chevy made it pull at such an angle to connect to the small hole in the sub frame. I just wanted to be sure I was not missing a bracket if it had one from the factory
Thanks again
Cheers Dale
Old 11-19-2012, 01:20:10 PM   #6
nonstopgo68
Thanks again
Cheers Dale
Did yours go to the hole by the mount?
Mabey I did get the wrong spring . GROUND UP !!!!!!!!!!!
lol
Old 11-19-2012, 02:16:57 PM   #7
earnhardtgm3
earnhardtgm3's Avatar
Here you go.
1979 White Z 2/8 T-Top----- 388 CI
Lunati Voodoo Retro Hyd Roller Cam
AFR 65cc aluminum heads-180cc competition model
Holley 300-36 intake
MSD 6AL Ignition
Holley 770 street avenger
Ceramic headers Pypes X pipe exhaust
350 Turbo w/2700 stall converter
3:42 w/auburn posi
My Z/28 Progress:
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is offline   Reply With Quote
Old 11-19-2012, 03:05:57 PM   #8
DW Holeshot
Hi again guys
I just got to my shop and the car is up in the air. I did get the spring connected to the slotted hole in the sub frame near the top , but its quite a stretch. Im pretty sure its the proper spring or it would not have reached at all. Maybe they intended it to be like this, and this tight to be sure the pedal is fully pulled back and keep it off the throw out bearing.
Thanks Earnhard , Ive seen that drawing, but none show or tell yah which hole to connect the darn thing to at the frame.
I may make my own set of headers snaking around things to get more of a semi long tube type that still has some decent ground clearance for these lowered cars. As many of you know, and from what I read you have to run the super shorties with the Z bar linkage. I dont want to do that
We make some pretty trick motorcyle headers and my brother in law Paul is a heck of a fab master.
Trouble is making headers by hand in small numbers cost allot and would be pretty pricey.
Thanks for the freindly advise
Dale @ Holeshot
Old 11-19-2012, 03:37:59 PM   #9
nonstopgo68
Im using the stock manifolds
Old 11-19-2012, 05:35:19 PM   #10
Protour-Camaro
Hi again guys
Dale @ Holeshot
I can't say much for a new spring, but yes its a little snug installed, as it should be. You don't want that sucker falling off or not pulling the fork back to rest.
Old 11-19-2012, 07:07:24 PM   #11
DW Holeshot
Yeah I agree with that one PTC
Now I need to figure out how to re size photos so I can show you a few lol
D
Old 11-19-2012, 07:42:55 PM   #12
grzewnicki
grzewnicki's Avatar
I made an "L" bracket and put it on one of my oil pan bolts and conencted the spring to that. Nice and straight, touches/rubs nothing. Simple fix.
1972 Z/28 350 HO Crate Motor with LT4 hot cam, TKO500 and 3.42.
http://www.nastyz28.com/forum/showth...ght=grzewnicki
If Jesus had a gun, he'd be alive today - Homer Simpson
"We started out wanting to change the world and found out all we could really do was help out around the neighborhood." Rick Danko (The Band)
grzewnicki is offline   Reply With Quote
Old 11-19-2012, 07:49:29 PM   #13
krabben1
krabben1's Avatar
Best pic of the spring I got.Cant really see where it goes into the frame,but at least it shows you how it runs.
Gen VI 454, Autogear M-22 W, Moser 12Bolt
67 Chevelle 468,P/G,10 Bolt
My build
http://www.nastyz28.com/forum/showthread.php?t=127870
krabben1 is online now   Reply With Quote
Old 11-19-2012, 08:38:35 PM   #14
DW Holeshot
Yep looks about the same angle as mine, so must be the slotted hole Im at also
Easy to move if you had to though
Cheers D
Click image for larger version
Name:	clutch return spring 1.jpg
ID:	14498  Click image for larger version
Name:	clutch return sprng 2.jpg
Old 11-19-2012, 08:51:42 PM   #15
DW Holeshot
Hey Krabben
I like your gray firewall. I know you have a BB, but what brand headers are those, they snake though there pretty good, are those 3" collectors, and is your exhaust tube below the sub frame or able to be about even with it ?
Cheers Dale
