Old 09-22-2012, 04:32:19 PM   #1
PEGLEG_1
which throttle bracket to use?
I am installing a hi rise intake with a demon carb. I have a 350 turbo trans.
Which throttle bracket do you guys recommend that I go with?
PEGLEG_1 is offline   Reply With Quote
Old 09-22-2012, 06:00:23 PM   #2
hhott71
hhott71's Avatar
You had what on there to begin with?
I reused the factory brackets. I bolted down it down on an original Torker, a '69 Z/28 Hi rise intake, a Victor JR a Holley 300-25
YES you must bend the bracket to line up the direction and the distance where the cable housing is anchored and such. I used a 10" crescent wrench, Vice grips etc. to make it work. I then removed it and painted it then bolted it back up and no one knew any different. COST? My time.
Looks? Just fine. Functionality? 100% perfect.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 09-22-2012, 06:08:47 PM   #3
PEGLEG_1
I don't have the factory brackets any more. when I got the car it had the cheap chrome bracket that goes under the carb mounting bolts. I change that out for one that bolts up using the intake manfold bolts. Was looking at the holley one that bolts up using the front and back carb bolts.
Old 09-23-2012, 04:47:09 PM   #4
night rider
I have used the cheap $9 summit chrome one on many diff setups over the years.. http://www.summitracing.com/parts/SUM-G1414/
1988 Camaro -
10.34:1 355, Brodix IK200 heads, 249/252@.050" .570"/.579" lift solid cam, holley 4150 HP 750, th-400, 3500 stall, ford 9" 3.89 gear
Vid clip of my 1988 camaro idling and reving.. New engine combo
http://www.youtube.com/watch?v=a6kfmy4IQQI
night rider is offline   Reply With Quote
Old 09-24-2012, 08:04:12 AM   #5
gingerbreadman
depends what demon you have but if its a 4150 style these things are excellent . good for throttle and kickdown.
there are cheaper imitations which can be as good and do the job in this same style. CSR and CVR do similar things.
http://www.summitracing.com/parts/HLY-20-112/?rtype=10
gingerbreadman is offline   Reply With Quote
Old 09-24-2012, 08:51:31 AM   #6
GOLF72
GOLF72's Avatar
GOLF72 is offline   Reply With Quote
Old 09-24-2012, 09:17:16 AM   #7
hhott71
hhott71's Avatar
The Racecar, no kickdown, I have a manual valve body 350TH
This next pick is the Blue 71 Camaro. It's all street, AC, Cruise, and the kick down. The car was a 2bbl as most Camaros were. The Q-Jet has different brackets. The bracket was bolted to the carb if I recall correctly for the Q-Jet. If you have a Z/28, the carb & intake and bracket should remain as is, maybe up grade the 4150 style 780 vacuum secondary Holley to a 650-800 cfm DP.
Holley #1850, Vacuum secondary 600 cfm on an Edelbrock Performer Intake.
I wanted a Q-Jet for it, but I couldn't find one that was worth the price. So I bought the Holley new for less than a rebuilt Q-Jet.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Old 09-24-2012, 04:42:17 PM   #8
PEGLEG_1
This is the bracket I bought. it should be here this week.
Old 09-24-2012, 05:01:31 PM   #9
EricsZ28
EricsZ28's Avatar
I have the same bracket. It is very nice.
Just as any FYI if you are running a dropped base air cleaner - check the clearance between your air cleaner base and the return spring on the bracket as you move the throttle. Mine hit, so I had to change up my air cleaner base for clearance.
EricsZ28 is offline   Reply With Quote
