Old 08-16-2012, 09:35:19 AM   #1
TURBOSCHILZ
70-81 4 Speed Reverse Lockout Rod
Hey guys, I'm just finishing up the restoration on my 1981 Camaro Z28, 350 L-81 Corvette motor, Saginaw no ring 4 speed... I have everything hooked up and she's running great, but I don't have the lower reverse lockout rod that runs from the lower point of the reverse transmission arm to the reverse lockout linkage on the frame... Being a Saginaw transmission, I'll need one from an older model, probably 70-77 as some of them were stock with the Saginaws... Does anyone know what length that rod is, part numbers, maybe have one lying around that you could live without?...lol It sure would be nice to finish up this awesome ride with some working reverse lights...hahahahaha
TURBOSCHILZ is offline   Reply With Quote
Old 08-16-2012, 09:31:26 PM   #2
twozs
i believe the Saginaw soldiered on to 81 model year .
twozs is offline   Reply With Quote
Old 08-17-2012, 12:26:31 PM   #3
4-speed
Here is some part#s I've Found
3975603
70-75 Camaro w/Saginaw 4-Spd.
70-75 Camaro w/Saginaw 3-Spd.
493453
74-75 Camaro w/Muncie (w/close ratio)
473072
78-81 F (M21,M24)
Russ
4speedconversions.com
4-speed is offline   Reply With Quote
Old 08-21-2012, 07:41:27 AM   #4
TURBOSCHILZ
Sweet, I will check into those part numbers and see what I can find out... Anyone have any idea how long the rod is?... Muncie's should of course be longer since the reverse lever is further back on the tranny, yes?...
Old 08-21-2012, 08:00:05 AM   #5
Fbird
Fbird's Avatar
go to the swap meet ...now......tons of 4 speed linkage stuff.
Fbird is offline   Reply With Quote
Old 08-22-2012, 07:09:18 AM   #6
4-speed
Some of these rods have a partial part # stamped into them.
Example : Part # 3975603 would have 5603 stamped on it.
Russ
