Old 08-12-2012, 08:41:31 PM   #1
2nd gen Guy
2nd gen Guy's Avatar
3rd gen rear end swap ????
So I have a nice posi unit and 3.73 gears that I got for my 3rd gen Camaro. I sent the diff out for blast and paint but wound up picking up a '80 Camaro ( my true LOVE, 2nd gen !!). It has nothing for gears or posi and I wonder if its possible to modify the 3rd gen diff to fit. I know the coil spring perch is wrong but I could cut it off so the leafs will work ? I do have welding and fab ability so I don't mind doing it if its workable.
Anybody have experience with this ?
2nd gen Guy is offline   Reply With Quote
Old 08-12-2012, 09:38:51 PM   #2
tjb408
the third gen rear is a 7.5 inch ring gear. and not near as strong as the 8.5 that would be under the 80. plus i think it is a lot narrower than the 80 would be.
tjb408 is offline   Reply With Quote
Old 08-12-2012, 09:41:34 PM   #3
BonzoHansen
LGM, Admin
BonzoHansen's Avatar
sell the 3rd gen rear for enough money to buy a new gear set for the 8.5" in your 80.
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
The looser the waistband, the deeper the quicksand. Or so I have read.
Bricka bracka firecrakcer shish boom bah, bugs bunny, bugs bunny, rah rah rah!
Feather-light suspension, Konis just couldn't hold. I'm so glad I took a look inside your showroom doors.
BonzoHansen is online now   Reply With Quote
Old 08-12-2012, 09:47:07 PM   #4
fabrik8
if you have a welder and fab skills why not just make a fourlink using the existing brackets. cit off the spring brackets and make some new coil over mounts and a nascar style sway bar and BAM!!! YOU GOT A ONE OF A KIND CAR. AS FOR THE GEARS. IF YOU HAVE THE MONEY JUST PUT SOME FORGED... oops, left the caps on... parts and make it bullet proof. unless the diff doesnt completely comprehend. good luck.
fabrik8 is offline   Reply With Quote
Old 08-12-2012, 10:14:56 PM   #5
PolarBear
I love hood, I love lamp
Thats pretty funny, you can brake a 3rd gen rear with a completely stock car.
Keep the rear from the 80 and rebuild that
Hey man, someone stole your battery....
I love hood
The artist formerly known as notchbackgta
PolarBear is offline   Reply With Quote
Old 08-12-2012, 11:01:26 PM   #6
Gary S
Reasons to not do it.
1. it has coil spring mounts
2. it is too wide for your car
3. it is a weak rear end
Reasons to keep your 2nd gen rear
1. It fits
2. It is much stronger than the 3rd gen stuff.
Gary S is online now   Reply With Quote
Old 08-12-2012, 11:53:17 PM   #7
2nd gen Guy
Well, my thots did run along the lines of just rebuilding the existing, figured since I have the 3rd gen it was worth looking into. The time line of events really s**k since I had got the posi just 2 wks b4 finding the 2nd gen. Now I got ALOT of rear end parts for a car I don't plan to finish !!!!! Thanks for the input... anybody want to buy a 3rd gen rear end ? LMAO !
Old 08-12-2012, 11:58:16 PM   #8
2nd gen Guy
Oh and last thot on the 80 rear end is its a 2.41 so from what I learned so far is the biggest gear I can go is 3.08 ?
Old 08-13-2012, 06:54:52 AM   #9
reedld
I think you need a 3 series carrier for anything 3.08 and higher ( 3.08, 3.42, 3.73, etc). They do sell adapter rings but some people do not recommend them (weak)
reedld is offline   Reply With Quote
Old 08-13-2012, 10:15:36 AM   #10
5spd540's Avatar
7.5 3rd gen rears are weak
5spd540 is online now   Reply With Quote
Old 08-13-2012, 10:24:48 AM   #11
Rich Schmidt
The 3rd gen rear is a good bit shorter. You could probably do it with really offset wheels. As others have said,it is either the wimpy 7.5 or Aussy 9 bolt(not as bad). It would be way better to sell it and add gears and posi to what you have,but if you have under 400 hp and dont plan on drag racing on slicks it is a viable low buck choice. Figure on spending $100 or a tick more to get perches put on plus at least a bastard U joint on the driveshaft. Since you can probably sell it for $300 for more plus the $150 or so in fab work you could probably get pretty far into the job of buying a decent stock posi,ring an pinion,half kit to install and the professional labor. The $450 you save by selling the 3rd gen rear plus a hundred or two out of pocket on top of that will get you the better rear that fits right.
Good luck.
1973 Camaro hot rod owned since 1989 runs high 12's. Mild 408 small block,th350,3.08 gears,ice cold a/c pumpin system ect.
1973 Firebird owned since 1994 runs mid 10's on motor and mid 9's on a 250 shot. BBC 439 2 speed,4.88 12 bolt,3600# full street car.
1970 Camaro ex pro stocker.
2011 Camaro RS,Jewel Tint.
2003 Silverado HD2500 and Wife's 2004 Malibu Maxx. Keeping my Family ALL GM!!!
Rich Schmidt is offline   Reply With Quote
Old 08-13-2012, 11:00:27 AM   #12
Gary S
If you have a 2.41, the only other gears that directly fit it are the 2.56. You have a series 2 carrier.
The 2.73 to 4.10 gears need a series 3 carrier, but that doesn't matter because you say that you need to add posi too so you will be replacing the carrier anyway.
Simply replace your series 2 non-posi carrier with a series 3 posi carrier and the gears of your choice.
Old 08-13-2012, 12:01:50 PM   #13
big gear head
If you are going to rebuild the 8.5 rear end that is in your car then I recommend going with 30 spline parts insteadof 28. The axles in the rear end are probably worn anyway and needto be replaced, so it wouldn't cost any more to upgrade to the 30 spline axles and posi. This makes the axles about 30% stronger or more. Moser makes direct fit 30 spline axles for this. Other manufacturer's axles need some modifications to make them work.
I guess you have already figured out that the 3rd gen rear end is not worth messing with. Go to www.thirdgen.org and list it in the classifides.
big gear head is online now   Reply With Quote
Old 08-13-2012, 10:14:20 PM   #14
2nd gen Guy
Yea, I don't think I'll bother trying to mod the 3rd gen. Its been on Craigslist for a cpl weeks now, I'll list it on the 3rd gen site when the site lets me, but as I said before it was a thot to use it if possible. The '80 Z I got is a sweet ride, but needs to be put back together. Has fresh paint, no rust ( I live in Mn where the salt KILLS LOL ), ALOT of new parts and a 327 with Vette heads on a stand.
I don't plan to build it to the point that I can't drive it to work ( 90 miles round trip !!), I just about over built my 305 in the 84 and it only gets about 12 mpg so cruisin to work is spendy !! The newest Camaro is actually my 8th , 3 were parts cars but I still owned em LOL !!
Anyway, thanks for all the advice, I'm sure I'll be back looking for more as my project progresses LOL !!!
