Old 08-10-2012, 03:55:11 PM   #1
Car Fabricator
Manual shift pattern HELP!!!
Have a very weird problem with the shift pattern, car is a factory 1979 4 speed Z28. Reverse is Left and Back, every Camaro shift pattern I have seen is Left and Forward. The owner owned one in his earlier years and remembers Left and Up. The main problem is that in this car, when you put it in reverse because it is left and back it hits the center console because it narrows in the back. Unlike if it went forward it would not hit because the console opens up more.
Any help would be much abliged.
1979 Camaro Z28 Saginaw 4 Speed with Hurst shifter. Cannot tell if it is a factory shifting unit with a hurst shifter lever added on or a complete hurst unit. In which, the hurst pattern was the same as factory. Just Weird!
Car Fabricator is offline   Reply With Quote
Old 08-10-2012, 04:03:41 PM   #2
Gary S
Try reversing the shift tang on the reverse lever on the tranny. If it is up now, face it down. If it is down, face it up.
Gary S is online now   Reply With Quote
Old 08-10-2012, 04:21:58 PM   #3
Rene Melten
Rene Melten's Avatar
Hurst made shifters for both options, with or without consoles. The shape of the stick and or the mounting bracket could come into play here. The only to know for sure is to list and compare part #'s.
http://www.hurst-shifters.com/?wpsc_...2%AE&paged =3
'73rs 350 .060 over,Super T-10,3.42 Posi,
AFR Heads, 670 Street Avenger, MSD, Hooker,
10 Bolt, Wilwood/GM 4 wheel disc.
http://i930.photobucket.com/albums/a...0.jpg~original
Rene Melten is offline   Reply With Quote
Old 08-10-2012, 05:31:26 PM   #4
COPO's Avatar
'79 Z28 with a 4-spd came with a Borg Warner not a Saginaw tranny.
Mark
70 Z28, M22, 3.73-Lunati 20120121 Retro Roller Cam
Testing out Brad Penn SAE 30 HP Oil
http://my1970z28.com/COPO/index.htm
Prev Z/28's
1968 Z/28
1971 Z28 4-pd
Z28's I ordered new:
1977 Z28 4-spd w A/C
1978 Z28 4-spd
1980 Z28 4-spd
COPO is online now   Reply With Quote
Old 08-10-2012, 05:45:09 PM   #5
Hoot
X2
1973 Firechicken "Troy Built"
Project thread http://www.nastyz28.com/forum/showthread.php?t=130791
Member of the Dark Side
Nothing to it, but to Duit !
Hoot is offline   Reply With Quote
Old 08-10-2012, 07:04:37 PM   #6
Car Fabricator
Its for sure a Saginaw...yay, another problem to deal with.
Old 08-10-2012, 07:12:40 PM   #7
Car Fabricator
Originally Posted by Hoot
X2
If its that easy I would be doing backflips!!!
Old 08-10-2012, 08:12:56 PM   #8
Gary S
A Saginaw likely has a different reverse shift pattern than the Borg Warner or the Muncie. This might be right for the tranny.
Old 08-10-2012, 10:07:26 PM   #9
77 rs
My '77 has the orig. Saginaw- no console- reverse left and down (lift 'R')
77 rs is offline   Reply With Quote
Old 08-11-2012, 12:03:07 AM   #10
Hoot
i have my saginaw set so reverse is up&left. You can change this buy the position of the linkage. You might not be able to just flip the linkage tang over. You might need a different one. All depends how the sloted hole lines up when you flip it over. You will also need to adjust the reverse linkage rod more then likely.
Heres what mine looks like. You can see the tangs. Tang to the far right is reverse. If you turn it so its pointing down it will reverse which way reverse goes into gear.
Old 08-11-2012, 07:20:04 AM   #11
JerryL
JerryL's Avatar
Saginaw Rev Linkage
I had a T-10 in my 79-Z, and currently a Sag 4-speed in my 73. Both patterns with factory shifters and consoles were lift to the left and up. Here is a photo of Sag Reverse linkage in my 73. I accidentally made the mistake of installing the linkage upside down in the 79 one time when reinstalling it, and 1st gear was 2nd and so on.
73LT 350/4-speed
Jerry
JerryL is offline   Reply With Quote
Old 08-11-2012, 10:43:00 AM   #12
cmonson
cmonson's Avatar
I have a sag in my 80. Reverse is lift up on the shifter, push toward driver door, slide all the way back toward the back seat.
Every sag I have seen is the same.
I could see as hoot said however if you wanted to reverse it.
cmonson is offline   Reply With Quote
Old 08-11-2012, 11:11:35 AM   #13
greencamaro1981
mine is set up as up and foreward so as "above" first gear
you'd better call Kenny Loggins because youre in the DANGER ZONE
1981 camaro, 1977 chevy truck, 2004 Avalanche, 2007 camry, 1954 ford crestline
greencamaro1981 is offline   Reply With Quote
Old 08-11-2012, 12:11:25 PM   #14
Fbird
Fbird's Avatar
swapping the lever would create some difficulties with the backdrive linkage?? hence the reverse lights
Fbird is offline   Reply With Quote
Old 08-11-2012, 02:57:30 PM   #15
Rene Melten
My '75 had a Factory Saginaw and the shifter ball looked like this...
