Old 06-21-2012, 10:45:18 AM   #1
1BAD78
1BAD78's Avatar
2500 Or 3000 Stall?
Hey guys after 6 months the tranny shop I got my tranny rebuilt at it going to put the proper stall in my Camaro. I told him I wanted a 2500 stall to begin with but he put a 1800-2000 stall in it and said I would like it better. Long story short he is going to put a new torque converter in at no charge and i'm just wonder what stall you all would go with 2500-3000? This is a mostly street driven car that might see very little track time. Check my sig for my engine setup. The tranny is a TH350 the rear gear is 3.42.
SOLD
1978 CAMARO Z28. 355ci 10:1 compression,Brodix I180s,comp xe274,eddy rpm intake,QuickFuel ss-650with annular boosters,MSD PRO BULLIT UTIMATE HEI,10" 3000 stall,3.42 gears. Summit Legends 5 wheels with 245/45/17 front and 255/50/17 rear.
1BAD78 is offline   Reply With Quote
Old 06-21-2012, 11:27:12 AM   #2
FatnLow
FatnLow's Avatar
Torque converters are a hard to figure out in imho. I wanted a higher stall so I bought a 10" 3000 from summit. It stalls up just fine but when I'm driving around in traffic it is weird because it is like I can't even feel the shifts between gears. I take this as torque converter slip. But if I'm at a stop and give it hell it works like a champ. Second gear rubber no problem. It is just me getting used to not much grab when putting around and it shifts. I could probably eliminate this by just shifting manually. Then it grabs gears no problem. In hindsight I guess my converter would be considered a loose 3000 rpm. What brand is the shop looking at?
I guess I'm just a noob at torque converter function. My previous converter was a 12" TCI Sat night special. It was great cruising around but I wanted to try a higher stall for strip action. Maybe I should have just bought a good set of tires to grip at the track before I went and got a converter?? It has been fun at the test and tune though.
FatnLow is offline   Reply With Quote
Old 06-21-2012, 12:02:53 PM   #3
1BAD78
1BAD78's Avatar
I really want a 3000, but i'm afraid it will hurt my drivability. So I dont know if I should play it safe with a 2500 or go for the 3000.
SOLD
Old 06-21-2012, 01:32:09 PM   #4
NYH1
Comp Cams recommends a 2200 plus stall converter. If it was me I'd go with a at least a 2500 stall converter. My cam is smaller then yours and I have a 2600/2800 stall converter. Run a good size tranny cooler and you should be fine.
NYH1.
'78 Camaro, mild Vortec head 385 stroker motor, 9.1:1 comp., 6" rods, Lunati Voodoo 262/268 hyd. flat tap. cam, Performer RPM Intake, 650 AVS carb, 1 5/8" full len. Hedman Headers, 2 1/2" full len. Flowmaster Dual Exh. Sys. w/Trans. Flow Muffler. TH350 Coan 11" 2600 stall conv., 10 bolt 3.42's Duragrip Posi, '70-'79 Z28 5 spoke mag wheels.
NYH1 is offline   Reply With Quote
Old 06-21-2012, 02:15:48 PM   #5
david.carlton@s
Curious about this topic. For a driver, why would you ever want a stall higher than your rpm when cruising on the open road or freeway? Wouldn't you want maximum efficiency when cruising? I have no idea.
david.carlton@s is offline   Reply With Quote
Old 06-21-2012, 02:38:52 PM   #6
1BAD78
1BAD78's Avatar
For me my Camaro is just a toy so I'm not worried about efficiency. The main reason I need a higher stall is because the converter I have now is too tight and is lugging my engine down at idle in gear.
SOLD
Old 06-21-2012, 02:55:39 PM   #7
andrew69_04
I would go somewhere between a 2500-2800 but not any bigger. you dont want to go to big becuase then your converter will be slipping when your up to crusing hwy speeds. you can burn them up in a hurry.
04-Mystichrome Cobra Vert 505hp/476tq
69 Camaro Z28 - 9" swap, LS1 T56
79 Z28 - LS2 Auto Build & Restoration in Progress
andrew69_04 is offline   Reply With Quote
Old 06-21-2012, 03:10:54 PM   #8
bigwilly81z28
+1
I use to run a 2400-2600 stall in a similar setup and wouldn't want anymore in mainly street driven car.
81 Z28
69 Camaro Pro-touring project
06 Grand Prix GXP LS4 daily dr.
Check out my progress thread
http://www.nastyz28.com/forum/showth...=1#post2732269
bigwilly81z28 is offline   Reply With Quote
Old 06-21-2012, 03:11:17 PM   #9
daniel76309
daniel76309's Avatar
My limited experience is that "advertised stall speed", or whatever you want to call it, is kind of vague. For example, what is labelled a 3000 stall may be way too loose or just right, depending on who makes the converter.
I can tell you that a converter which is too loose might get you down the dragstrip in a hurry, but it sucks for normal street driving. I had a converter that was supposed to be 3000 stall, but I had to rev the engine a lot to get the car moving, and it would "flash" to over 4000 in higher gears. When it hooked up at full throttle it really moved, but part throttle at lower RPM's it just felt sloppy. And, as mentioned above, it eliminated the "shift feel" almost completely. I had it "tightened", and am much happier with it now.
Bottom line, I would say when in doubt, go with a lower stall (unless you are just using the car for drag racing).
daniel76309 is offline   Reply With Quote
Old 06-21-2012, 04:30:55 PM   #10
1BAD78
1BAD78's Avatar
Thanks guys! I think a 2500 will probably do it for me. The stall I have in it now the tranny shop said it should stall around 1800-2000 but its more like 1500-1800.
SOLD
Old 06-21-2012, 05:17:47 PM   #11
the cam and torque converter must be matched in order to get the stall just above your engines max torque range
muscl car is offline   Reply With Quote
Old 06-21-2012, 05:21:38 PM   #12
73Camaro383
73Camaro383's Avatar
Also have to consider the cruising speed rpm so you dont have all sorts of slippage from what ive read.
73Camaro383 is offline   Reply With Quote
Old 06-21-2012, 05:23:31 PM   #13
1BAD78
1BAD78's Avatar
Comp suggest a 2400+ stall for the XE274, but this cam really dont start shakin till around 3000rpm.
SOLD
Old 06-21-2012, 11:13:47 PM   #14
FatnLow
FatnLow's Avatar
Well I guess since my converter is so loose I might as well throw a bigger cam in it. I also need to invest in a tranny jack.
Old 06-22-2012, 12:31:23 AM   #15
there used to be a website somewhere that showed cam dur @ .050 to torque converter stall to properly select your converter for the best performance
