06-17-2012, 01:34:30 AM
#16
Please don't.
My '81
'81 Camaro: 5.7L '86 350 LT9, Edelbrock Performer Intake man., Edelbrock 600 carb., Drop base air cleaner, unnamed headers, pypes crossflow exhaust, ECP all aluminum radiator, Mark VIII electric fan, PTFB GT suspension, single adjustable AFCO shocks, C/E subframe connectors, 4-speed.
06-17-2012, 05:54:37 PM
#17
2JZ-GE- non turbo Supra/ IS300 motor
2JZ-GTE - single turbo Supra motor
2GZ-GTTE - twin turbo Supra motor
the blocks, pistons, heads and cams are different across all 3 variants.
I had an IS300 5speed auto. It was a quick car.
What is your point of doing this besides the its different factor? I mean early 2nd gens came with I6 250's so its not like your really doing anything different.
If your wanting something more efficient than a V8 consider using a turbo V6 from a new Regal or something like that. They make great power are quiet and quite efficient. That 2JZ really isn't that efficient. My IS got like 24 MPG on the highway where as my LS6 00' T/A got 30 MPG on the highway (it only got 9 mpg around town though :/ it wasn't stock).
I have no problem sticking swap motors in stuff. Id like the have a Gen II Viper LS swap. At least then the viper wouldn't sound like ass, it would be lighter, better balanced and still make the same power. If not more.
06-17-2012, 11:18:28 PM
#18
Pimp Micktastic
Sandy Hook RIP Little Angels-Charlotte Bacon,Daniel Barden,Olivia Engel, Josephine Gay, Dylan Hockley, Madeleine Hsu,Catherine Hubbard, Chase Kowalski, Jesse Lewis, Ana Marquez-Greene, James Mattioli,Grace McDonnell,Emilie Parker, Jack Pinto, Noah Pozner,Caroline Previdi, Jessica Rekos, Avielle Richman, Benjamin Wheeler,Allison Wyatt.
Also remember the Teachers/Guardians who lost their lives
06-18-2012, 05:08:15 AM
#19
Well if I really wanted to do it it would just be because it would be unique. Am I thinking this is going to happen? Probably not. An LS swap would be much easier on the wallet and there is plenty of support since it has been done plenty of times. I do still think that it would be interesting though.
07-01-2012, 10:38:19 PM
#20
Personally I like it. I believe the GTTE motors had forged cranks, rods and pistons. You get a high flowing DOHC head, intake and twin turbos. The engine is tough as nails and routinely makes 600hp on stock bottom ends. They came with the 6 speeds as well. I have seen the front clips on ebay for like $6K which includes the engine, trans, intercooler, computer and clutch hydraulics. I don't think getting this into the subframe of a 2nd get would be either very hard or expensive outside of the initial buy in.
71 Formula, 455 with ported 96 heads, Crower solid lifter cam, HSD/800DP, TKO 600, 3.73 Eaton posi.
07-01-2012, 11:07:33 PM
#21
Pimp Micktastic
I've read multiple different areas they have gotten 1000hp on stock internals.
One of the reasons the motor was so sought after.
07-07-2012, 09:36:28 PM
#22
6K is a lot. For a motor. you can easily buy an LSx variant and 6speed and have it installed for less than 4k
07-29-2012, 02:23:56 PM
#23
This thread caught my eye because i've got a 1980 camaro rs with a 267 V8 that I plan on tossing anyway, and there is a mid eighties turbo supra sitting in the backyard...so, realistically, would transplanting it be cheaper than buying a crate 350?
07-30-2012, 11:52:39 AM
#24
Depends do you know for sure that the motor in that car is any good ?
You also have to think of a way to mount it to you current trans or to use the supra ?
07-30-2012, 12:17:57 PM
#25
The Birdman of Carlisle, LGM
I had two Supras (one normally aspirated, one turbo). Those years are notorious for blowing a head gasket and it's a PITA to replace. I had one blow.
The 2JZ motors fixed this problem.
07-30-2012, 08:59:15 PM
#26
Might be a great engine. It's kind of like swapping a Ford or Mopar into a chevy. You may like it but nobody else will. Reasale will be zero unless it's swapped out.
Will always sound like a 6 cylinder.
Just my .02.
Oh and last weekend at Car Craft 6.0 71 Nova. Not mine did 640 RWHP on the chassis dyno. Single turbo. Using the 12 lb spring on 91 octane.
07-31-2012, 02:14:30 PM
#27
Location: Muskegon, MI (the beer tent capitol of the world)
Honestly I liked everything except the exhaust tips on the video car. As for swaps. I have a buddy doing the unthinkable. He has a LQ4 and has swapped the heads for CNC'd LS3's with a GMPP hot cam. He topped that with one of the new QFT slayer 750's. The trans is a Monster Trans 700R4. The recipient? A 04' Dodge ram short box 2WD that is slammed on 20's and 22's.
We have been drilling/ adapting all the GM sending units to accept the Mopar stuff so the dash instrumentation all works. I haven't got pics yet but we have fired it on the engine stand. When all the bugs are worked out, it's time to weld. The stock 4.7 is like 8" wider than the LS and with an electric fan we have all the room in the world to use the stock drive shaft with a conversion joint. So its as simple as mounting it really.
I say swap what ever into what ever. I like crazy stuff. Turbo GN 3.8 in a Cobra kit car, seen it. 454 in a Ford EXP yup 9.90's all day.
PTFB Comp. Suspension, Control Arms, SFC's, Steering, Bushings, G-Bars and Sway Bars
383 w/ ST10 4 speed
3.73's
LS brakes front and rear
17x 8/ 17x 11 Torque Thrust II's
Every penny!
08-01-2012, 11:41:37 PM
#28
Doubt that but if you say so. I am talking about a full front clip which includes all of the electronics, accessories, radiator, intercooler, trans and clutch stuff. Not saying all of this stuff will work but most of it should and ebay may not represent the best buyers market anyway. My point was that the price is not out of line for what you get.
08-02-2012, 12:36:58 AM
#29
I looked into the engine bay of the Supra, not a 2JZ, but A 7M-GTE. I personally think it would be better than a 267!
I'm new to Chevy's, my daily driver is a Dodge Diesel, so... I guess i'm not too worried about originality, love that body though!
08-07-2012, 11:01:11 AM
#30
7m-gte's suffer from oil starvation, check into that and how to solve it before you do the swap or youll find yourself buying several more engines and ultimately spending more than using a 350sbc.
2jz gte engines are great, they usually support 600whp on the stock internals, the 1000whp stuff on stock internals is just a myth, they do get 1000whp on the chassis dyno, but blow up the moment you take it to the track. i have a friend with a 1023whp supra, he got 42x whp on the stock engine and stock turbos ran an entire season with that setup + 50hp of nitrous the car ran 11.0 on that setup, later he went for a single turbo setup that gave 6xx whp, that setup lasted 4 months and got the car to low 10 before starting to blow by, after that he swaped to aftermarket rods and pistons, new turbo, aftermarket cams + 75hp of nitrous and got 1023whp wich made the car go 9.2 on a 6 speed, the car is a "street car" full interior, 3200lb (with driver).
besides the different/wow factor i see no advantage for you guys on making the camaro 2jz (around here the 2jz longblock + wiring and ecu cost 2,000 and the lm7 costs the same) it would be better to go with a 5.3/th400 combo since parts for the 2jz are much pricier than chevy aftermarket parts(my friends cars clutch alone costs 6,000USD).
76 camaro 476 bbc 10:1, solid roller, xr280, 8.5 10bolt, 4.11 detroit locker, moroso trick springs, strange front single adjustable shocks, caltracs , rancho 9000 rear shocks, shooting for 11.5 on motor
| Thread Tools |
| Display Modes |
Linear Mode
