Go Back   NastyZ28.com > Regional Discussion, Events & Clubs > California 2nd Genners
Old 09-14-2005, 02:18:00 PM   #1
ClovisHye
Like to hear from central valley owners
Any 2nd gen clubs in Fresno area? Restoring a 76 coupe and could use local advise. Need a lot of body work and interior. Drive train was new when I bought it. 350 4bl stock w/turb350.
76 Coupe out of the loop
ClovisHye is offline   Reply With Quote
Old 09-15-2005, 05:49:00 PM   #2
rogerh
I am in Hanford, just about 35 miles south of you. I have a '77 currently being worked on.
You can't help getting older, but you don't have to get old.
"Excuse me, I'm an old fart."
Life is like a jar of jalapeno peppers ....
What you do today, might burn your ass tomorrow.
rogerh is offline   Reply With Quote
Old 09-16-2005, 02:44:00 AM   #3
RonLyn
We're in Dinuba. guess thatmakes us almost neighbors. We've been working on a 72 for 2 1/2 years. Drop us an email if you want.
Lyn
Lyn
RonLyn is offline   Reply With Quote
Old 11-04-2005, 02:40:54 PM   #4
roughneck427
hi guys im in caruthers and work in lemoore i have a 71 z/28 working on it for 2 years also
roughneck427 is offline   Reply With Quote
Old 11-04-2005, 09:33:01 PM   #5
70 Z UC
Los Banos here, I've got a 70SS & a 73 plane jane.
70 SS Camaro. Bought new by my uncle in 69. I bought it from him in 95, frame off resto in the works.
07 Duramax (11.80 @ 115.849 1.623 60') Stock motor, stock single CP3 (injection pump), SCV trans, MPI twins, 30% injectors, EFI Live tuning, 33x12.5-17 Baja MTZ's 7,640lbs
http://www.youtube.com/watch?v=PdCIK_GtVe8
70 Z UC is offline   Reply With Quote
Old 11-05-2005, 10:54:02 PM   #6
Happy Johnson
I'm in Fresno. I have a 70 RS.
Happy Johnson is offline   Reply With Quote
Old 11-08-2005, 10:26:19 AM   #7
rogerh
Anyone here in central valley ever do rear end work? I have a posi unit and some gears that I want to install and need some guidance and/or assistance.
Thanks
Old 11-08-2005, 09:45:09 PM   #8
70 Z UC
I've done a few. Just a few tips
* Pre crush the crush sleeve before installing (Much smoother)
* Mic washers on both sides, it will give a good starting point.
* I set lash a little tight (but don't kill it), it will loosen up slightly.
Everything else is pretty much basic Mechanics (Almost)
Old 11-09-2005, 05:58:41 PM   #9
roughneck427
hey people have some extra parts from a 71 should post this in the swap meet section but you guys are local and a little eaiser to get the stuff to also have lots of good early style cores blocks heads cranks and so forth
Old 11-11-2005, 06:34:54 PM   #10
undertow
I live in Fresno. I have a 71 SS. Interior new, in the process of replacing piston.
71 Camaro SS350
under for the third time.
i've been baptized by your voice.
it screams from deep beneath the endless water.
and it's half as high as heaven
and half as clear as reason.
undertow is offline   Reply With Quote
