05-16-2012, 12:24:32 PM
#1
gas coming out air horn
Just put the carb on and fired up the engine. Fuels is coming out the back air horn like a geyser. I tried adjusting it with the wrench and flathead but it just got worse. is there a way to adjust this or am I goi.g to have to open up that side of the fuel bowl. its a 650 dp
05-16-2012, 12:42:27 PM
#2
Sounds like there's trash in the needle/seat, holding it open.
Corky
79 Z28 bought new, honeymoon ride same year, still have same wife, same car.
05-16-2012, 12:47:49 PM
#3
Set up ignition switch so flames will blow out the front of the vehicle!!!  That'll get attention!!!
Vin Number Look up
Camaro Diagrams
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote."
-Benjamin Franklin
."Easy to shoot, big clips, 100+ bullets in each, large velocity guns"
-Sen. Diane Feinstein
05-16-2012, 12:59:14 PM
#4
Good place to start too.
77 Camaro Z28 (To my grave) 04 Monti Carlo LS (my daily driver)
05-16-2012, 01:19:26 PM
#5
That was the issue with my carb when it did the same thing
05-16-2012, 01:20:22 PM
#6
try tapping the fuel bowl with the soft end of a screwdriver a few times to see if you can jar the needle closed. Best bet is to pull that needle out and see if its shot or has something stuck in it.
05-16-2012, 01:29:57 PM
#7
Haha thats awsome
05-16-2012, 01:31:45 PM
#8
I'll have to try this when I gey out of work at 11
05-16-2012, 01:36:54 PM
#9
Did you ever turn the carb upside down before installing it? It's possible that the float may have moved far enough to jam the needle while inverted. As suggested, try tapping on it. Either way, you will have to pull it apart and check.
It could also be too much fuel pressure.
You can't help getting older, but you don't have to get old.
"Excuse me, I'm an old fart."
Life is like a jar of jalapeno peppers ....
What you do today, might burn your ass tomorrow.
05-17-2012, 10:56:08 AM
#10
That is a great idea! When he blows the horn it will shoot a flame and they WILL move oout of his way!
05-17-2012, 01:03:07 PM
#11
Float is stuck to the bottom. Remove the sight plug and use some thing small through the hole to lift the float., then adjust float and don't run it dry until you check out the bowl/float off the car. Some times they just stick to the floor.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
| Thread Tools |
| Display Modes |
Linear Mode
