Old 04-17-2012, 05:09:24 AM   #1
JasonZE
anyone running 4x4 roller cams?
Just recieved my new 383 block/roller lifters and factory dogbones/spider etc and looking a cams again
My engine guy says he has used the comp 4x4 cams and they give awsome low and mid range pull which suits a road car like mine with stock converter and 3.08 rear Im at around 9.6 compression.
Im currently tappin away with a flat tappet 268h cam and quite like it so looking for at least something similar in a roller cam
Any input welcomed!
Jason.....
JasonZE is offline   Reply With Quote
Old 04-17-2012, 10:20:28 AM   #2
BondoSpecial
BondoSpecial's Avatar
I am running the largest comp marine roller cam in my 79 with 10:1 compression and world sportsman II heads. I would not worry what name is on the cam (marine, 4x4, etc) that's just a recommendation. In my case the XM276HR is the same grind as the XR276HR car cam, but on a 112 LSA instead of a 110 LSA. I wanted the wider LSA for a slightly better idle for EFI friendliness.
Steven H. www.carfap.com
2011 Infiniti M37X, 2004 Ford F250 6.8 V10 6 speed manual 4x4, 2000 BMW M5, 1999 C1500, 1994 Town Car, 1976 Jeep DJ5
BondoSpecial is offline   Reply With Quote
