Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 04-09-2012, 06:50:51 PM   #1
old cam dynamics hyd cam
this is an old single pattern cam from cam dynamic that is now listed under crane cams energizer cams 302 dur/500lift .is this still a good cam it is a strong mid range 3400-7200rpm and 246 @ .050 specs
Performance usage, good upper RPM torque and HP, bracket racing; Heavy, Pro ET, Super ET, etc., auto trans w/3500+ converter, oval track; Street Stock, Enduro, Hobby, etc., 3/8- 1/2 mile, 10.5 to 12.0 compression ratio
http://www.cranecams.com/product/car...detail&p=23763
Old 04-10-2012, 12:34:21 AM   #2
450bench
Yes it is a good cam...I ran that exact cam in a Vega with a 327 in it years ago...It's cut on a 106 and with flat tops and 62 cc heads, maybe 10 to 1 compression, it ran 7.00s and 6.90s in good weather...Sounded like a freight train...Quick revs and started making power around 3000 if I remember...
That motor is now in my friend's 66 chevy II...Freshened it up last years and runs strong...Makes around 6 inches of vacuum in his car so I set his 750 dp up a with 2.5 power valve
Sounds similar to the old 754 chevy cam
450bench is offline   Reply With Quote
Old 04-10-2012, 04:17:04 AM   #3
hhott71
hhott71's Avatar
I ran the next size smaller 286 enforcer in the flat top 350 I had for decades. Went as quick as 12.06 with 041 heads in the Vega, and finally as quick as 11.30's regularly with Canfield heads. .473" lift , It's now a Crane energizer cam.
The 306 Enforcer is the Cam you describe and should prove to be quite powerful.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 04-10-2012, 07:46:21 AM   #4
REARSPROCKET
I use to run this one, which was the Cam Dynamics 294 Energizer and it was very stout on the street.
http://www.cranecams.com/product/car...detail&p=23962
That cam is hotter and I'm sure it's going to be very choppy.
79 Camaro 355, 11:2:1, 462HP@6.8K. AutoGear M-22,4:10s,GW BMBs,C/E SFCs+Caltracs,PTFB goodies.Go Get Em Ben #11
REARSPROCKET is offline   Reply With Quote
Old 04-10-2012, 06:39:14 PM   #5
thanks guys !!!
Old 04-15-2012, 10:39:36 AM   #6
sweetsoul
i put that same cam in a 305 i built a few years ago.it had flat tops , 52cc heads and a single plain intake and we got just over 400hp on the dyno.
http://www.nastyz28.com/forum/showth...ight=sweetsoul
When in doubt....Gas it!
sweetsoul is offline   Reply With Quote
