04-08-2012, 11:42:03 PM
#1
runs hot at highway speeds
I have or rather my son has a 78 camaro with a stock crate 350 in it with 350 turbo trans. He was headed up 75 and the temp gauge climbed to about 240 to 250 degrees. He got off at the nearest exit and checked the water level and had to add some. When he took off again the temp dropped down but climbed up again when getting up to speed on the highway. He say the temp is ok driving around town but runs hot out on the highway.
I was looking for some tips on troubleshooting this.
first could it be a bad water pump and or the clutch fan is weak?
04-08-2012, 11:44:51 PM
#2
sounds like a bad clutch fan. exactly the reason i made the switch to an electric set up
04-09-2012, 10:12:36 AM
#3
There may be adequate airflow at highway speeds even if the fan is crapping out.
Maybe the motor is leaning out? Plugged fuel line and/or filter(s)?
Dave Cozzi
1970RS Camaro.
Tons of "go fast goodies" but, still does not move.
04-09-2012, 10:25:35 AM
#4
BANNED
A few things that can cause overheating problems at freeway speeds are: colapsing radiator hose, restricted radiator (corrision in the tubes most often), partial stuck t-stat, air in the cooling system, blown head gasket (lets air into the cooling system), also debris in the radiator fins (leaves, dirt etc) can limit airflow, a bad radiator cap that cant hold pressure.
Basicly you need to look real close at the cooling system and start checking things out.
04-09-2012, 01:32:05 PM
#5
now that i think about it i had the same problem when my radiator was crapping out. aside from being a small 2 core, it was old. replaced it with a nice aluminum 3 core and ive never overheated again. id say maybe try and flush the radiator first.
04-09-2012, 04:39:18 PM
#6
I think I will try a flush first. I never pulled the radiator in that car. It had a good motor no coolant leaks so never touched it.
04-09-2012, 04:59:03 PM
#7
try a flush and clean the rad fins of any debris check pump for proper operation at high rpm's. Check your mixture maybe to lean and check timing and make sure its not to far advanced. I seen exhaust glow form mixture and or timing issues. Things may run hotter with the steady rpm highway cruising.
Good luck!.
Ps. make sure a hose is not collapsing like the bottom hose... Its supposed to have a steel spring/sleeve... Not sure what its called but its to keep the hose from collapsing.
***Bullets and octane***
1979 camaro, sp/cp w/ 74 (cmj) "Police special" 350SBC
"Twistin' the mains and beatin' the brakes... Off my cars and my women"
04-09-2012, 05:01:58 PM
#8
Good luck!.
Never mind dont touch your timing but id still check to see if you may be running lean.
04-09-2012, 05:03:57 PM
#9
Have the radiator cap and cooling system pressure checked. THEE most overlooked overheating problem is the radiator cap!
Cardinal
04-09-2012, 05:08:02 PM
#10
+1
04-10-2012, 03:34:31 PM
#11
+1, if the pressure isn't an issue, look to the radiator. Mine was doing this last year, it would very gradually heat up, and heat up even faster on the highway, and would never go down until i shut the car off. Ended up putting in a new radiator and it fixed the issue. My old stock one was getting gummed up with deposits, not allowing the water pump to flow the water through to cool.
1974 Camaro Z28
383 Stroker, 4-bolt main, Forged bottom end, flat top 2VR pistons, 11:1 CR
Single Plane High Rise Intake
Mighty Demon 750 carb
RHS Aluminum heads, 68cc chambers, 210 runners,1.5 full roller rockers
520/540 lift, 241/249 dur, 110 lobe sep, Solid Lunati Voodoo cam
Built Turbo 350 tranny, with shift kit, 3500 stall converter
Posi rear-end with 3.73 gears
Dyno'd at 420 RWHP
04-10-2012, 03:51:10 PM
#12
back flush systems are pretty cheap and very easy to install!!
Vin Number Look up
Camaro Diagrams
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote."
-Benjamin Franklin
."Easy to shoot, big clips, 100+ bullets in each, large velocity guns"
-Sen. Diane Feinstein
The Shadows betray you, because they belong to me.
-Bane
04-10-2012, 08:40:40 PM
#13
I do not have the spring that goes in the lower hose. Do you still them in?
04-11-2012, 12:04:20 AM
#14
Yes you do need the spring in the lower hose.
Michael
1962 Corvair panel van, 1967 Buick GS400 Convertible, 1970 RS/SS Camaro, 2000 Mercury Gran Marquis, 2009 F450 crew cab Lariet 4x4, 1954 Triton Motorcyle( original cafe racer.) 1967 triumph Bonneville chopper.
04-11-2012, 09:07:01 AM
#15
My brother in law has a Weiand water pump on his Chevelle. When he raced his temp would shoot up to the sky on the big end. He told me he didn't know what was causing it. We let the car cool down, then started checking. I had him start the car and he whapped the throttle. The lower hose was completely collapsing because of the high volume water pump. He has since installed a spring and now no issues.
1979 Camaro-soon to have a 500+ci BBC, turbo 400 with brake and a Moser 40 spline hand built 9 inch
2003 Silverado ext cab-5.3 K&N cold air, 3" exhuast and 285/75 Kelly Safari TSR's
1991 Harley Davidson FXR-Built by yours truly
| Thread Tools |
| Display Modes |
Linear Mode
