Go Back   NastyZ28.com > Drivetrain & Performance > VIN, Trim Tag & Drivetrain Decoding
Old 04-04-2012, 01:01:26 AM   #1
Andyp
Andyp's Avatar
Borg Warner T-10 1978 Z28
Can anyone decode this casting number? I know the 903 designates an aluminum case. I canít get info on the numbers prior to the 903. Thanks
Andyp is offline   Reply With Quote
Old 04-04-2012, 11:08:47 PM   #2
TheFastForester
TheFastForester's Avatar
Andy, I have a '78 Z with the original Borg Warner T-10 as well. I have not been able to decode those numbers either, here is what is stamped on my case:
Transmission Passenger Side Casting: 1304065 903
W.G. Div.
FpC1
Keith
Project Progress
My Camaros
1978 Z28
TheFastForester is offline   Reply With Quote
Old 04-29-2012, 09:02:04 PM   #3
Niveus81
Niveus81's Avatar
The information that I have is that the entire 13-04-065-903 is a part number, the 13-04 designates a T10 model and the 065 says that it is the case/housing and then as you know the 903 is aluminum. 902 was grey iron, 903 aluminum, and 904 was nodular iron. You will have numbers on your tail shaft/extension housing as well, that should be 13 04=T10 model, 066=tail shaft/extension housing, 90x(mine reads 901? still working on this one). You will also find numbers on your side plate(drivers side) 13 04=T10 model, 097=side plate, 90x. On the side plate most likely you will also find a date code that will start with a letter followed by 2 two digit numbers example: J 29 82 which would indicate a cast date of J=September, 29=day of the month, 8=1978, 2=second shift. Month codes as follows: A=January etc. through December with the letter I being excluded which makes J=September. That being said I have seen date codes that end simply with the year 79, 80, etc. Also, if the T10 is original to the car there may be a partial VIN stamped on the case/housing(top passenger side). I hope this helps.
Niveus81 is offline   Reply With Quote
Old 04-30-2012, 12:40:32 AM   #4
Andyp
Andyp's Avatar
Thatís awesome. Thanks for the info. Mine is original, time to search for the vin...
Looking for a 1978 Rally Sport
1972 Camaro Z28
Old 04-30-2012, 01:30:25 AM   #5
Niveus81
Niveus81's Avatar
You're welcome. When you find the VIN the first 3 digits can be decoded, division, year, and plant. If you want to post it I will try to help with that too.
