Old 03-07-2012, 09:04:31 PM   #1
HULKZ28
ring gear bolts
does anyone know if all 8.5 10 bolt ring gear bolts are left hand thread??
including aftermarket ring gears..
Thanks
RWF
1980 Z28
355 vortec solid cammed 10.5;1 422 in progress 11:1 comp afr 210 heads 250 solid roller
videos
[url]http://www.youtube.com/watch?v=g3pUJKqnxxc
[/urhttp://www.mypowerblock.com/video/vortec-running-027l]
HULKZ28 is offline   Reply With Quote
Old 03-07-2012, 09:14:53 PM   #2
djorgensen3
The last set of gears I put in had left hand threads on the ring gear.
djorgensen3 is offline   Reply With Quote
Old 03-07-2012, 09:26:39 PM   #3
HULKZ28
when i removed the stock 3.08s a few years back I stripped the first bolt not knowing it was left hand thread..I dont want to do the same when taking out the 3.73s that are in there now..for some reason I think they were rh thread..
Thanks
RWF
1980 Z28
videos
Old 03-08-2012, 08:32:01 AM   #4
big gear head
All 8.5 and 7.5 corporate 10 bolt ring gear bolts are left hand thread.
big gear head is offline   Reply With Quote
Old 03-08-2012, 09:34:50 AM   #5
Twisted_Metal's Avatar
Thanks
How much torque does it take to strip a ring gear bolt?
Your board name makes sense now!
Old 03-08-2012, 12:13:08 PM   #6
Philly
When you guys re installed the ring, did you use loctite on the bolts or any other stuff to help?
1973 camaro 454 BBC, 4speed super T-10 close ratio
781 heads, 8.5 gm posi 3:73's
My thread
http://www.nastyz28.com/forum/showth...67#post1649667
Philly is offline   Reply With Quote
Old 03-09-2012, 09:43:31 PM   #7
HULKZ28
They were Left Hand thread..Thanks guys..I would use a small drop of red loctite on the clean/dry bolts.
RWF
1980 Z28
videos
