Old 02-28-2012, 06:58:31 PM   #16
Twisted_Metal's Avatar
Double check that you have the leaf spring pin in the alignment hole of the lower plate.
I accidentally had one misaligned when I redid my leaf springs a few years ago.
I noticed it when I tightened the nuts on the u-bolt (beneath the lower plate)and it seemed to bow more than the other side before it got tight.
The pin wasn't in the hole!
I took off the plate and had a local machine shop use a press to get it flat again.
I was much more careful the second time I assembled it.
Hope it's that simple!
Good Luck!
Twisted_Metal is offline   Reply With Quote
Old 02-28-2012, 09:29:27 PM   #17
1971CamaroGuy
ok thanks again
I should mention that I have a 1" block and spacers in my set-up too...nit sure if that makes a difference.
Dennis
1971 Camaro - work in progress
My Build: http://www.nastyz28.com/forum/showthread.php?t=241037
I'm still making speaker kick panels, just closing on a new home due to close 5/01/2013. I have a few sets ready to ship so feel free to ask me about that.
1971CamaroGuy is offline   Reply With Quote
Old 03-03-2012, 05:34:02 PM   #18
1971CamaroGuy
I got out and installed my sway bar today, while I was at it I double checked my leaf spring. I ended up putting in new u bolts and after everything was tightened up my drivers side is 1/4" more forward than the passenger.
I don't think the car was ever in a major wreck or had the quarter replaced
If anything i might be able to take the spring pocket on the drivers side and notch the area where the clips slide into the body and the bolts attach.
I think it will be ok as is, I hope I'm not being too anal about it??
Dennis
