02-05-2012, 11:26:20 PM
Carburator Rebuild
Just wondering if anyone could point me to a good rebuild kit for my carburator.
I also need to know what type of carb i have....lol..its a original 79 Z
The numbers on the car are:
Quadrajet 17059216
0279 CMA
When i look at the Haynes guide i see M4M, M4MC....not sure what that means either...any help would be appreciated
79 Camaro Z28 - A work in progress!
02-06-2012, 02:20:13 PM
Would this work....and does it look like in contains everything i will need?
http://www.ebay.com/itm/Edelbrock-Qu...sories&vxp=mtr
02-06-2012, 02:34:03 PM
Originally Posted by Millz90
This would be better price at your local AZ and they can ship it to you as well.
http://www.autozone.com/autozone/par.../N-imeezZ8vd1z
You will need the float and fuel filter as well.
My daily driver: 2006 Silverado 1500 extend cab, 5.3L, "Sylvia".
Wife's Grocery Getter: 2001 Buick Century
My toy since June 1983: 1978 Camaro Type LT: Iron block LS6, 2004R, 3.42 posi.
http://www.chevythunder.com/Camaro%2...igh%20view.jpg
Wife's toy since April '78- 1973 Mustang Grande 351C 2V #'s match.
02-06-2012, 02:36:09 PM
Quadrajet 17059216
0279 CMA
You have the M4MC, which means it has a manual choke (heated by the tube to and from the intake manifold on the passenger side).
M4M, has the earlier vacuum break choke which you dont have.
02-06-2012, 02:41:41 PM
Ok i just put a new fuel filter in which was only $2 at autozone. Should i get a different kit that has a float? Can i buy just a float?
02-06-2012, 02:52:00 PM
The float is a seperate item.
02-06-2012, 03:33:34 PM
Don't take a chance with Ebay. Take your carb number and go to your local auto parts store. They either have the correct one, or can order it for you.
02-06-2012, 03:39:01 PM
^ +1
The one you linked on eBay is for a 795 cfm Q-Jet. (Truck application, IIRC.)
Your Q-Jet should be a 750 cfm unit.
I don't know if the rebuild kit is different between the two but it would be better to get it locally.
02-06-2012, 04:55:32 PM
ok...thanks for the info....
How difficult is it to rebuild anyway? Is it pretty simple?
Do i need some kind of cleaning liquid to soak the parts in?
Is this a free guide/step by step to do this?
02-06-2012, 05:30:34 PM
#10
02-07-2012, 01:16:53 PM
#11
perfect! Those are good videos actually.
I think getting the carb loose from the engine is going to be harder then rebuilding it.
02-17-2012, 08:38:42 AM
#12
So i was tearing the carb down and as i though someone has already rebuilt it.....very clean in side...no muck at all.
So i though i was doing it for nothing but once i saw the bottom and the little inserted pieces i dont think they used the right epoxy or it just needs redone.
Can i just take all of the OLD epoxy off and put new on? Will these pieces snap into their holes?
There seems to be 2 in the front of the carb that they epoxy over and then the 2 that im showing in the pictures......
02-17-2012, 10:13:14 AM
#13
I also have a zip file in my signature on quads.
02-17-2012, 10:37:37 AM
#14
ok...does it address these things? on the bottom?
Im not sure what their called. Should i just be able to epoxy them over and be ok?
Channel plugs...i see now. but im still not sure if they should be forced into their holes or do they just kind of sit on top. They seem to have a little gasket on them
02-17-2012, 10:46:21 AM
#15
LGM, Admin
if you want your original carb have it rebuilt locally. there must be a good carb shop in your area somewhere.
i've never had good luck with parts store replacements.
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Originally Posted by big gear head
Just remember, if you can't afford to do it right the first time then you can't afford to fix it the second time.
Where's that confounded bridge?
