01-30-2012, 10:15:59 PM
#16
Thanks Man! Thats very helpful.
07-09-2012, 11:01:46 AM
#17
Did you get it all done? 5-6 months since the last post.
I'm putting a T-56 350-TBI combo into my son's '72 using the stock '97 T-56 Bell, and I'm going to try to adapt the Hyd master and slave from the 97 SS donor. anyone done that?
07-09-2012, 11:30:32 AM
#18
Yes, you can do that. You will need to use the 97 clutch and flywheel also (assuming it is a 1-pc rear main seal engine like it should be if TBI.
80Z build thread
11:1 forged 383 w/ AFR 195s, .575/.584 roller, 1000cfm Accel EFI, T56 6spd w/ SPEC 3+ clutch, Moser 8.5" w/ 4.10s, 12"f/11.6"r disc brakes w/ line lock, Hotchkis springs & sways w/ PTFB stopflex, 18s w/ 255/295 Nittos, Slide-A-Links w/ 275 Mickeys, elec fan & water pump w/ battery in trunk, 4th-gen interior w/ Equus gauges & custom bezel
My Chevy garage GEARHEAD dezign
07-09-2012, 08:40:37 PM
#19
I know the engine and trans will bolt together, I have all the flywheel, clutch and pressure plate, my question is, has anyone adapted the stock LT1-T56 Hyd master and slave to a 2nd gen, I was also wondering if the flywheel balance is different, I read quite a few times in here, and at a 3rd gen forum that they are balanced the same for a 87 up 350(TBI, TPI, vortec, etc.) thanks for the reply
| Thread Tools |
| Display Modes |
Linear Mode
