Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 01-03-2012, 06:19:20 PM   #1
1BAD78
1BAD78's Avatar
Quick Fuel Slayer carbs.
Have any of you guys used one of these carbs? The price is great on the features that it come with it.
http://www.jegs.com/i/Quick+Fuel/793/SL600VS/10002/-1
SOLD
1978 CAMARO Z28. 355ci 10:1 compression,Brodix I180s,comp xe274,eddy rpm intake,QuickFuel ss-650with annular boosters,MSD PRO BULLIT UTIMATE HEI,10" 3000 stall,3.42 gears. Summit Legends 5 wheels with 245/45/17 front and 255/50/17 rear.
1BAD78 is offline   Reply With Quote
Old 01-03-2012, 06:37:20 PM   #2
bigbad79
It does look like a great carb for the price, I've considered trying one out. Not a fan of my street avenger 670.
'79 Z28, built 350....soon to be 4 speed
bigbad79 is offline   Reply With Quote
Old 01-03-2012, 06:42:58 PM   #3
1BAD78
1BAD78's Avatar
Really. I was considering a street avenger, but I think ill pick up this quick fuel. I'll wait and see what others say about it.
SOLD
Old 01-03-2012, 06:46:51 PM   #4
71RS/SS396
I don't know anything about the Slayer series but I have 2 Hot Rod series carbs and I'm very satisfied with the way they perform.
71 RS/SS 396 Resto-Mod
Placer Gold Sold
71 SS LS -3 Stock #'s matching
Mulsanne Blue
69 RS/SS Pro-touring
61 LeSabre 2dr post
70 Z/28 Track Car Build http://www.detroitspeed.com/Projects...maro-pg-1.html
http://www.superchevy.com/features/1...carbon-carver/
http://www.hubgarage.com/mygarage/losabre
71RS/SS396 is offline   Reply With Quote
Old 01-03-2012, 06:57:33 PM   #5
GM72_SuperSport
The only differences i see between the Slayer and the big brother Hot Rod series is that the Slayer does not have a secondary metering block. I would take any of these carbs over the street avenger. Much more versatile carbs. changeable idle air and high-speed air bleeds and quick adjustment secondaries. Perfect for a street car in my opinion
Mike
1972 SS Camaro- 10:1. Edelbrock RPM heads. Comp xe268. 1.5 comp ultra pro magnum roller rockers. Performer RPM intake. Barry Grant 650 Speed Demon Carb. Msd distributor. Hedman headers. Dual flowmaster 2 1/4 h pipe exhaust. 3:42 posi rear. Th350
GM72_SuperSport is offline   Reply With Quote
Old 01-03-2012, 08:48:58 PM   #6
jpekarek
It does look like a nice carb. Just another version of the old Holley though, which is a great carb. I tuned a guys '70 Chevelle 400SB two weeks ago with one of these Slayer carbs. Just like workng on a Holley, everything worked just the same. Car ran great after setting it up correctly. I wouldn't mind using one, price seems good.
The Street Avenger carb is not much different then the other Holley's. Just a slightly different outward appearence and different out of the box tuning mainly. They can really ALL be made to run the same. Even the Edelbrocks, they are infinetely adjustable on the primary and secondary circuits. I like the Edelbrocks mainly because you can make all adjustments and tune anything without removing the carb from the engine or even draining the bowls.
The biggest problem I run into is people assuming that when they buy a carb that it is "ready to run" out of the box. Nothing could be further from the truth. Your engine will "start" out of the box but in my experience 100% of carbs are NOT set up to run correctly on YOUR engine out of the box. The floats are always high and the idle circuit is always rich. This stuff needs to be set up before you run the car much.
All carbs of any manufacturer operate basically the same, they all have the same circuits and all operate on the same design principles. They just adjust differently. This is where the brand stigma comes from. Even the Quadrajet will perform just like a Holley when set up right. Not better or worse, just equall when the circuits are correctly set up for your car.
James
1970 Chevelle SS Wagon, 541 Reher and Morrison full roller big block
1979 Z28, built 350, 4 speed
1931 Model "A" w/327 auto
jpekarek is offline   Reply With Quote
Old 01-03-2012, 10:12:26 PM   #7
CamaroMan79
CamaroMan79's Avatar
Never heard of that series of carbs, but it seems like a pretty good deal. I might have to look into them more. I am looking for a carb for the 390 in my 62 F100. I rebuilt the vintage Holley that was on it but I'm still having problems
What don't you like about it? I have a 770 on my 383 and couldnt be happier with it except for that my carb stud broke off inside it when the carb fell off my workbench. So now I have it JB welded in there.
1978 Z28: forged roller cam 383 stroker, AFR Heads, AED double pumper
CamaroMan79 is offline   Reply With Quote
Old 01-03-2012, 11:18:04 PM   #8
dragrace505
I have the Quick Fuel Q-750-AN, and I really like it. I had a 670 street avenger, and was nothing but problems.
dragrace505 is offline   Reply With Quote
Old 01-03-2012, 11:41:02 PM   #9
bigbad79
Well I expect a little lag with a vacuum secondary carb, but it's ridiculous with my street avenger. I have changed jets, accelerator pump cams, secondary springs....and I've adjusted the accelerator pump several times and it just bogs off the line NO MATTER WHAT. And I know it's the carb, because I took it off and put on a friend's old Holley 750 and it did great.
Old 01-04-2012, 08:51:44 AM   #10
1980RS
I bought a VS 750 here from a guy, ran great untill you stomped on it then mine had the same problem. I out my old 3310-1 on the same engine and did not have any hesitation. Makes me wonder what is different with the 2 carbs. As I remember from back in the 70's I never had any hesitation with holleys back then, a few bogs no and then but no hesitations. I sold the carb at a swap meet.
1980RS is offline   Reply With Quote
Old 01-04-2012, 01:52:08 PM   #11
bigbad79
I might just pick up a Quick Fuel 750....and get rid of the street avenger for good.
Old 01-04-2012, 02:46:55 PM   #12
1BAD78
1BAD78's Avatar
The guy at the local speed shop said this quick fuel carb would be better for my motor.
http://www.quickfueltechnology.com/c...hot-rod-series
He said it was more tunable with the four corner idle, but it cost $100 more.
SOLD
Old 01-11-2012, 07:44:05 PM   #13
CamaroMan79
I went ahead and pulled the plug on one of these Slayer carbs. I got it today. It looks pretty nice. Ill get it put on tomorrow and report back.
Old 02-28-2012, 05:22:23 PM   #14
br80z
any update on the quick fuel carb? I'm considering buying one myself
www.brgraphicdesign.com
www.goteeshirt.com
1998 Camaro - Daily Driver
1980 Z28 - Much assembly required!
br80z is offline   Reply With Quote
Old 02-28-2012, 05:35:43 PM   #15
CamaroMan79
I got it on my Ford 390 and the motor fired right up. I cant drive the truck down the road right now because I don't have bumpers, bed or tabs for it yet. The truck is on the back burner till I can find a 64-66 shortbox bed for it (been looking for a year) with no luck. Once I drive the truck a little bit I can check the plugs and adjust from there.
The the finish reminds me of the Edelbrock carbs.
