01-02-2012, 12:39:01 AM
#1
Any tricks to keeping armrest from pulling out?
I can't keep my armrest from pulling off! I've tried toothpicks, bigger screws, and new holes! What else is there?
Keeping your foot off the pedal of a muscle car is like taking a hooker to dinner...that's not what you're spending the money for.
1980 berlinetta 355/th350: Gone
1979 camaro 305/th200: Gone
1977 camaro LT 305/th350: Gone
01-02-2012, 12:42:08 AM
#2
is the armrest itself broken? or are the screws pulling out of the door
01-02-2012, 12:45:10 AM
#3
They keep pulling out of the door. Nobody ever pulls harrd on them, but any little pull yanks them right out.
01-02-2012, 12:47:38 AM
#4
If you have a mig welder... You can put a couple of beads of weld around the enlarged holes to give the screw something to bite into.
01-02-2012, 12:51:57 AM
#5
i've used a dolly and hammer to flatten out the hole too, i pushes the metal back into the center
01-02-2012, 12:53:16 AM
#6
I'll try smashing them in a little better, and if that doesn't work ill try mig. Thanks for your help!
01-02-2012, 02:33:21 AM
#7
A couple of pieces of wire stuck in the hole works. + all of the above
01-02-2012, 06:27:03 AM
#8
Get yourself a riv-nut tool (should have been done this way from the factory). If you arent familliar with what it does, it is a threaded insert that screws onto the tool, then you put it into the hole as if it were a rivet. Once you have it in there and it is squeezed in tight, you remove the tool and you now have threads to accept a bolt.....much much stronger. I bought mine at the local Fastenal store.
01-02-2012, 09:38:35 AM
#9
I like this idea! I'll be looking for one of these! Thanks.
Tony
01-02-2012, 02:37:27 PM
#10
Yeah, these are excellent for bolting things to sheetmetal. I've used them all over the place. Great way to mount up my radiator fan and stuff like that.
Arte et Marte
Open Header video
ZZ4 short block, wiseco 10:1 forged under brodix IK200s w/ rpm air gap, 670 street avenger, 1 3/4" hooker super comps, pypes X 2.5" Pro-V, 200-4R, quicksilver shifter, 3.73 w/ posi.
My project thread
| Thread Tools |
| Display Modes |
Linear Mode
