Go Back   NastyZ28.com > Body & Chassis Restoration > Interior Restoration
Old 11-27-2011, 02:27:57 PM   #1
red78z
evaporator box part question
what is the bottom heater core tube rubber boot on the evaporator box called? i am doing the ac delete and the rubber boot for the bottom core tube is shot , id like to get a new one to help keep the water and debris out
red78z is offline   Reply With Quote
Old 11-27-2011, 03:33:27 PM   #2
red78z
bump
Old 11-27-2011, 04:18:31 PM   #3
red78z
bump for rewording
Old 11-27-2011, 04:41:06 PM   #4
Rene Melten
Rene Melten's Avatar
Assembly manual calls it a grommet.
'73rs 350 .060 over,Super T-10,3.42 Posi,
AFR Heads, 670 Street Avenger, MSD, Hooker,
10 Bolt, Wilwood/GM 4 wheel disc
http://s930.photobucket.com/user/73r...423-1.jpg.html
Rene Melten is online now   Reply With Quote
Old 11-27-2011, 04:45:24 PM   #5
red78z
would it be called an evaporator grommet? thanx for the reply ill try finding that
Old 11-27-2011, 05:04:20 PM   #6
Philip
that Nova Guy
Philip's Avatar
Without AC the drain is not needed.
77 Nova 406, TKO-600, 3.73 posi, GM 4 wheel disc
Philip is offline   Reply With Quote
Old 11-27-2011, 05:13:24 PM   #7
red78z
what i need it for is the hole on the ac delete box is bigger than the lower heater core tube , i want it to cover the heater core tube and prevent water and debris from going in there and laying against the firewall
Old 11-27-2011, 05:20:49 PM   #8
red78z
i found them on yr.1 and npd , they want 25 bucks for that piece of rubber , ill just measure the core tube and the delete box hole and buy a oil dipstick tube grommet
Old 11-27-2011, 05:44:33 PM   #9
Philip
that Nova Guy
Philip's Avatar
I have used that foam insulation for pipe. Slide it on the tubes after cutting it to a length that will hold it tight against the housing.
