11-25-2011, 08:05:45 PM
#1
Someone wanna measure something for me?
If you have your car on jack stands, or a lift.
From the back of the block, where the bell housing/trans mounts, to the machined FACE of the snout on the rear differential (behind the dust cover on the yoke) I have 81".
I feel like Its an inch closer (causing a potential driveshaft issue if my suspension completely compresses) than it should be.
I'd love to hear from one or two other guys.
-- Joe
88 Formula, 412 SBC, AFR 210, NX276HR, Singleplane EFI, Procharger, T5, scattershield, hyd TOB, built 3.73 10 bolt. 600+ hp.
11-25-2011, 09:43:19 PM
#2
From your instructions mine measures 82". B/W ST-10, 48" drive shaft, center of yoke to center of yoke..
11-25-2011, 09:49:22 PM
#3
Thanks!
So my engine/front frame is 1" too far back, or my rear end is 1" too far forward.
If I check one or two more spots, do you think you could check yours for me and report back the measurement found? At this point I'm guessing the front frame is too far back, but there is also a good chance the pins are sheared and the rear end is too far forward. ?
-- Joe
11-25-2011, 09:52:26 PM
#4
I'm not sure that full-compression is the worry. If the front half of the rear springs is truly horizontal at ride height, then yes. Otherwise, the worry is at full droop.
I can check for that 81" or 82" late tomorrow afternoon.
11-25-2011, 10:02:07 PM
#5
Originally Posted by anesthes
Thanks!
-- Joe
Yup, just ask what you want measured.
11-25-2011, 10:23:50 PM
#6
Thank you!
Here is the first one. What I did was on the bracket for the leaf spring, I guess the mount bracket, I took the rear bolt and measured from the center of that bolt to the axle tube. I get 20 1/2"
That, I hope will at least tell me if my axle is in the right spot in relation to the leaf spring.
Next, I wanted to see if my front subframe is too far back, so I looked at the side of it and there is these like 1" holes. I put the tape measure in the most rearward hole, and measured to the eye of the leaf spring and I got 37 1/2"
Thank you!
-- Joe
11-25-2011, 10:49:50 PM
#7
I think we found it. Again with your pics. I got 21 1/2" and 38 1/2".
11-25-2011, 10:53:27 PM
#8
My 79 measures about 5/8" off everyone else's cars in that dimension, although mine is too long, and my subframe is in perfect alignment and my rear is on the dowel pins of the new leaf springs. Chalk it up to build quality. I had to have a custom D-shaft made for what should have been a straightforward swap.
Steven H. www.carfap.net
1985 BMW 745i Turbo, Euro model import, 18" Antera wheels
1986.5 Porsche 928S, 5.0 32v V8, 18" 993 turbo wheels
1988 K1500, 5.7 TPI swapped
1999 C1500, new 5.7 Vortec, 4" lift spindles, EFILive V2 tuner
2003 Mercury Marauder, 4.10s, Heinous billet rear control arms, SCT Advantage III tuner
2004 Taurus SEL, Ingalls tubular control arms
11-25-2011, 10:57:22 PM
#9
Hold on, I'll remeasure that 20 1/2" again, was a little confused, you said bolt! Be right back.
11-25-2011, 11:00:07 PM
#10
Did you see my T5 swap thread?
This no look right...
-- Joe
11-25-2011, 11:02:30 PM
#11
Can't find a 20 1/2" measurement.
11-25-2011, 11:02:59 PM
#12
I did. Like me, you have a custom driveshaft in your future. The 45.5'er did not work for me even though it should have.
11-25-2011, 11:06:57 PM
#13
your rocker panels are identical to the girlfriends car that im working on right now. Car was painted burgandy over blue and they didnt get the bottoms haha, i almost thought someone stole the car for a second
11-25-2011, 11:10:36 PM
#14
Hrmm.
So from this bolt:
to the tube, what do you get?
Thanks!
-- Joe
11-25-2011, 11:11:22 PM
#15
I'm too lazy to get on my knees when I paint.
-- Joe
| Thread Tools |
| Display Modes |
Linear Mode
