Old 10-28-2011, 12:17:06 PM   #1
JCSilver80
Trunk Lock Cylinder Alignment Issues, Please Help
There was no lock cylinder for the trunk when we bought the car. Other damage in the past or just using a screwdriver to open the trunk for who knows how long had bent the sheet metal around the opening. I have flattened it back out to where it looks correct to me. I ordered a cylinder shaft from Classic and am trying to use it with a lock cylinder from a 3rd gen that I had laying around. The geometry is way off. The cylinder points upward and puts the shaft in a bind when you try to rotate the cylinder to undo the latch. Either my sheet metal needs more massaging, or the lock cylinder I am using is too long. Can someone post a picture of their cylinder, shaft, latch set up so I can figure this thing out, thanks.
JCSilver80 is online now   Reply With Quote
Old 10-28-2011, 06:15:05 PM   #2
76 camaro car 1
The pictures are not good but I hope this helps.
Save a life,become an organ donor. ______________ Support the wounded warrior project.
76 camaro car 1 is offline   Reply With Quote
Old 10-29-2011, 12:15:37 AM   #3
JCSilver80
Thanks for the pictures 76. Mine is different than yours. I should have specified the year, mine is an 80 so I need to see pictures of a 78 to 81. I didn't realize there were three different rear panels for 2nd gens.
