Old 10-20-2011, 08:43:23 AM   #1
woody80z28
woody80z28's Avatar
tick/rattle from engine under load
The 357 I just built has a tick/rattle that you can hear under load and I can't figure it out. The best way I can think to describe it is "diesel-like" in sound. At idle and past about 2500rpm you can't hear it.
It's not spark knock, I've checked the knock sensor with a hammer and it works, and pulling timing didn't help.
I thought maybe it was from the small weld pinhole in my fabbed exhaust (which is the only leak I could find) and fixed that last night with no change in sound.
Oil pressure & level is good. 80psi cold and about 40 warm at idle according to the stock gauge.
Could it be a lifter or something mechanical? The engine has less than 150 miles on it so far. I converted the engine to an OE-roller setup and adjusted the lash a half turn past the pushrod spinning by hand (same as I have done with my other SBC).
It runs well, but just doesn't sound normal.
80Z build thread
11:1 forged 383 w/ AFR 195s, .575/.584 roller, 1000cfm Holley HP EFI, T56 6spd w/ SPEC 3+ clutch, Moser 8.5" w/ 4.10s, 12"f/11.6"r disc brakes w/ line lock, Hotchkis springs & sways w/ PTFB stopflex, 18s w/ 255/295 Nittos, Slide-A-Links w/ 275 Mickeys, elec fan & water pump w/ battery in trunk, 4th-gen interior w/ custom gauges
My Chevy garage GEARHEAD dezign
woody80z28 is offline   Reply With Quote
Old 10-20-2011, 08:19:54 PM   #2
Pfrederiksen
XE cam?
P
Pfrederiksen is offline   Reply With Quote
Old 10-20-2011, 08:24:26 PM   #3
woody80z28
woody80z28's Avatar
Nope. Stock LT1 F-body cam.
80Z build thread
Old 10-20-2011, 11:40:37 PM   #4
woody80z28
woody80z28's Avatar
Uh oh.
Decided to check my valve lash and I could spin the pushrods by hand. So I tightened them until they stopped spinning (maybe 1/8 turn) and gave them a half turn of preload. Went back through to double check and they all could spin by hand again. So I gave them another half turn. Went to start the engine and it wouldn't fire.
So I backed them all off and adjusted them opposite of the open valve like I always do and must have missed one in a hurry. Sounded like the engine ran on 7. So I went through and did them all one by one adjusting them just a little after valve closing.
Now it sounds like I have one distinct lifter tick. Did I collapse a lifter running it with too much preload?
And - the original sound is still there.
80Z build thread
Old 10-21-2011, 08:26:50 AM   #5
Pfrederiksen
Adjust them with the motor warmed and running.
P
Old 10-21-2011, 12:17:31 PM   #6
phbmd
I hope you fix your problem with some simple upper valve train tuning.
But I always remember a friend's 400 T/A that started running a little weak and made a tapping/clackety sound when he got on it....his turned out to be a broken cam lobe. Hope yours is simpler, but I thought I'd share it.
1979 Z28 Black/Carmine - 4 speed
http://www.nastyz28.com/forum/showthread.php?t=175071
phbmd is offline   Reply With Quote
Old 10-21-2011, 03:09:32 PM   #7
woody80z28
woody80z28's Avatar
The lifters were used out of a salvage L31 Vortec engine. Maybe I'll just pull the intake and drop in a brand new set to rule it out.
80Z build thread
Old 10-26-2011, 10:05:29 AM   #8
woody80z28
woody80z28's Avatar
Can a collapsed and/or otherwise noisy lifter straighten itself out? The distinct lifter tick I was hearing has gone away and the engine is running great. I bought lifters, but I'm wondering if I really need to swap them in.
80Z build thread
Old 10-26-2011, 01:03:08 PM   #9
middleagecrisis
If the motor is running good, I'd chalk it off to the lifters being out of adjustment and run it as-is.
middleagecrisis is offline   Reply With Quote
Old 10-26-2011, 01:12:28 PM   #10
Air_Adam
This is outta left field maybe, but I've heard it in alot of mid-90s and newer 350/LT1/LS engines with a stock bottom end... are you maybe hearing some piston slap? Does it change with temperature? I've heard a few stock, untouched LS1 engines that had some wicked piston slap when cold, that would mostly (but not entirely) go away when warmed up. GM called it normal, and I've never heard of any problems that came from it. My '97 LT1 did it a very little bit too when cold (usually up to around the temp the guage would start to read), and it never caused me any problems either. It fits the 'diesel-like sound' description.. especially the LS engines lol.
What bottom end is in your motor?
Spandex is a privelige, not a right!
Air_Adam is offline   Reply With Quote
Old 10-26-2011, 02:00:42 PM   #11
BondoSpecial
BondoSpecial's Avatar
sounds like a bad lifter. I have definitely gotten the odd used, bad OEM roller lifter. They don't last forever. My lt1 cammed oem roller motor is totally silent running, you should not have tapping.
Steven H. www.carfap.com
2011 Infiniti M37X, 2004 Ford F250 6.8 V10 6 speed manual 4x4, 2000 BMW M5, 1999 C1500, 1994 Town Car, 1976 Jeep DJ5
BondoSpecial is offline   Reply With Quote
Old 10-26-2011, 09:30:57 PM   #12
woody80z28
woody80z28's Avatar
I didnt think it was the difference in FT/roller lifters I was hearing, because my Beretta is full roller and quiet as well.
The engine has stock crank & rods with new hyper pistons. Hot/cold doesnt make a difference.
I'm just gonna drop my new LS7 lifters in and be done with it.
80Z build thread
Old 10-27-2011, 10:12:37 PM   #13
gingerbreadman
what method or formula are you using when adjusting your rockers ? are you waiting for exhaust to start rocking then adjust intake or are you doing them one cylinder at a time with a formula. reason i ask is there a chance you are messing one or more up?
gingerbreadman is offline   Reply With Quote
Old 10-27-2011, 11:36:17 PM   #14
BondoSpecial
EOIC method and a half turn on those and they should be the quietest valve train ever
Old 10-28-2011, 11:20:18 AM   #15
RS1970
My 2000 model chevy truck with a 5.3 sounds like a coffee can full of marbles at first cold start of the day. Piston slap is a understatement.
My old 6.0L gmc did too, just not as bad. For the record, my 5.3 has well over 200k and aside from cold start noise is the best engine I have ever had.
RS1970 is offline   Reply With Quote
