Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Old 10-05-2011, 04:37:55 PM   #1
1hot1970
TCS switch, relay, and selonoid
I have a 1970 Camaro 350LT-1 with an M-21 4sp, can anyone tell me what the purpose of the TCS switch does on the trans along with the TCS relay and Selonoid at the carburator ????? What is the purpose of these items ?? And what do they do... Any answers... Thanks Rich
1hot1970 is offline   Reply With Quote
Old 10-05-2011, 08:19:14 PM   #2
twozs
read. its the same for chevy .... http://www.highperformancepontiac.co...ems/index.html
PITA
twozs is offline   Reply With Quote
Old 10-05-2011, 10:37:47 PM   #3
gin man
Since the 70 model didn't have an EGR valve, the TCS alone worked to decide when to allow vacuum advance. Based on engine temperature and gear selection, the solenoid would open to allow vacuum to be applied to the distributor advance mechanism.
The basics of the system were the solenoid, a coolant temperature switch and a transmission switch that was activated in 3rd and 4th gear.
1970 RS, 350, 4 speed, original owner.
gin man is offline   Reply With Quote
Old 10-06-2011, 04:08:53 PM   #4
1hot1970
Thank you very much, I have all these on my 1970 and I was wondering if it was worth keeping on, but since they all work in conjunction and controls my vacumm advance I think I will leave it alone. Thanks Buddy
Old 10-06-2011, 09:32:48 PM   #5
gin man
You could actually remove everything and the car will run fine, just with more emissions. It simply means that you have advance in all gears regardless of engine temperature.
