Old 08-27-2011, 03:30:54 PM   #1
Sparky555
1979 camaro z28 5.7 L emission diagram
Does anyone have a diagram that shows the original equipment that came in a 79 z28. I live in ontario and the Ministry of enviorment is coming after classic car for polution equipment. I think it only have to be in the car it does not have to work. We don't require an emmision test but we do requir to have the original smog equipment on board.
If someone can help that would be great I tried looking on line but no luck
Thanks
Angelo
Sparky555 is offline   Reply With Quote
Old 08-27-2011, 04:30:07 PM   #2
Twisted_Metal's Avatar
Maybe.... Ask the Ministry of Environment what they expect to see?
I would have a catalytic converter, a restricted fuel inlet (unleaded only), an EGR valve, a PCV valve and possibly an AIR pump with the corresponding manifolds.
I don't know what the rules were for a Canadian car back then.
Was it built for export to Canada? (KPH instead of MPH speedometer)
Old 08-27-2011, 05:27:22 PM   #3
Kamikaze
Kamikaze's Avatar
Angelo,
PM me you email and I can sen you pics .of the factory vacuum diagram and underhood sticker
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 08-27-2011, 08:32:55 PM   #4
mgoad1971
mgoad1971's Avatar
You'll also want to hook up your charcoal filter as well.
Vin Number Look up
Camaro Diagrams
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote."
-Benjamin Franklin
."Easy to shoot, big clips, 100+ bullets in each, large velocity guns"
-Sen. Diane Feinstein
The Shadows betray you, because they belong to me.
-Bane
mgoad1971 is offline   Reply With Quote
Old 08-27-2011, 09:00:51 PM   #5
Sparky555
I am for sure going to hook up tha charcoal canister just for the gas fume alone.
Iam running a stock block with a mild cam
edelbrock carb and intake
holley valve covers
hooker headers
2 1/2 " dual stainless exhaust with magna flow mufflers and high flow cats
I hope I can make the old polution work with these slight changes.
The only thing is the vac pump is this what they call the smog pump?
I also intend to put back the pcv and egr I belive the egr will also help with idle
Thanks
Old 08-27-2011, 09:55:26 PM   #6
Air Injection Reactor (A.I.R.) pump.... Yes, That's the "smog" pump.
(Pumps air into the mainfolds, it's not a vacuum.)
Old 08-27-2011, 11:08:15 PM   #7
COPO's Avatar
Thanks
Angelo
It must have everything it had when new and it must turn and have a belt such as the smog pump, no exceptions. Each infraction will cost you about $350.00. Say bye bye to your headers unless you get someone to weld the smog tubes in them.
Mark My 70 Z28 Web Site http://www.nastyz28.com/~copo/index.htm
Twitter
Qjet rebuilt etc http://www.nastyz28.com/~copo/qjet.zip
Old 08-27-2011, 11:22:00 PM   #8
Sparky555
Are you serious i can not run headers? everyone runs headers back in the day the first thing to come off were the exhaust manifolds. I asked two MTO officers and they told me that they would not bug me with the headers as long as I had cats, egr and vac pump.Do you know for a fact that they are looking for headers.
The 79 I don't think even had the smog tubes I think they came into play in 80 and 81
Can someone that has been pulled over by these smog cops confirm if they were running headers and what did they say about them.
This whole thing is making reconsider even finishing my project.
Old 08-27-2011, 11:28:56 PM   #9
mgoad1971
mgoad1971's Avatar
Damn, and I though California emission testing was bad!!!!
Vin Number Look up
Camaro Diagrams
-Benjamin Franklin
-Bane
Old 08-28-2011, 02:45:11 AM   #10
Kamikaze
Kamikaze's Avatar
Diagrams sent via e-mail!
Old 08-28-2011, 05:49:36 AM   #11
mgoad1971
mgoad1971's Avatar
Could I get them too Kamikaze? Thanks in advance!!
Vin Number Look up
Camaro Diagrams
-Benjamin Franklin
-Bane
Old 08-28-2011, 02:51:57 PM   #12
79ZED
No smog pump on Canadian or Federal 79 Z cars. Diagram in the service manual is correct except the Thermac ( heated air intake ) is not shown.
John
79ZED is offline   Reply With Quote
Old 08-28-2011, 04:57:08 PM   #13
Sparky555
John
So are you saying that A 79 z28 did not have a smog pump. So am I only suposed to have the charcoal canister hooked up to the PCV and the ERG valve? My Car was born in Canada and first registered in Alberta Canada.
What is this thermac you are talking about?
Thanks
Angelo
Old 08-28-2011, 05:39:46 PM   #14
Kamikaze
Kamikaze's Avatar
B
PM me your email and I will send you the diagrams
Old 06-06-2012, 10:38:13 PM   #15
rpn
Kamikaze would you kindly send me these diagrams also.? Thanks in advance.
rpn is offline   Reply With Quote
