Old 08-24-2011, 09:03:29 AM   #1
Airborne
Airborne's Avatar
TCS Solenoid & Vacuum Lines
As the interior is being done on my car I wanted to tighten up some issues I found while inspecting it. I noticed that there is another port on my carb that is plugged with a cap. When I went through the assembly manual to match everything up I found what was missing.
The assembly manual calls it the SOL-Spark Cont. I am assuming this is a fancy way of saying TCS. Now I have found the TCS and Vacuum line set at camaro central. http://www.camarocentral.com/Product...D1029&CartID=3
What I am looking for is confirmation that this is the one I need. I am a bit concerned as it says it is bolted to the carb but the assembly manual clearly shows it bolted on the block by the passenger side valve cover. If this is not the one then where can I find it?
I found where they cut the electrical plug near the firewall and I will fix that. Is there anything else I should be thinking of? Pics of what right looks like would help. Thanks in advance!
1970 Camaro SS L34 (Norwood)
Camaro Gold, Saddle Interior
Courage is fear holding on a minute longer.
George S. Patton
Airborne is offline   Reply With Quote
Old 08-24-2011, 09:53:29 AM   #2
COPO's Avatar
Here's the location from my 70 Z28. The number of vacuum lines may differ on the 396.
It bolts to the intake with a bolt that has threads at both ends. The upper threaded portion is for the nut to hold down the switch.
Mark
70 Z28, M22, 3.73-Lunati 20120121 Retro Roller Cam
Testing out Brad Penn SAE 30 HP Oil
http://my1970z28.com/COPO/index.htm
Prev Z/28's
1968 Z/28
1971 Z28 4-pd
Z28's I ordered new:
1977 Z28 4-spd w A/C
1978 Z28 4-spd
1980 Z28 4-spd
COPO is online now   Reply With Quote
Old 08-24-2011, 10:32:27 AM   #3
Airborne
Airborne's Avatar
Thanks Mark! I'm going to order the TCS, bolt and Vacuum lines. The TCS from camaro central looks identical.
Now I ran across the TCS relay while wire tracing and I will order it to. I assume it is bolted to the firewall somewhere? Now I have to run wires for it. The purple goes to the neutral safety switch, dark blue goes to the TCS along with the blue from the trans switch. Okay, where does the dark green wire go? Is that some kind of ground on sheet D2 of the assembly manual? It just ends in the middle of nowhere.
George S. Patton
Old 08-24-2011, 10:35:22 AM   #4
Airborne
Airborne's Avatar
Crud! I forgot to ask about the vacuum lines. Are yours all rubber or do you have hard lines for the TCS as well? This is why.... http://www.camarocentral.com/Product...2D393&CartID=2
George S. Patton
Old 08-24-2011, 10:42:41 AM   #5
70 SS/L78
The TCS solenoids between the small block cars and big block cars are different, they have different p/n. I've never compared them side by side but I believe the mounting bracket is a little different. It does mount on one of the Intake manifold bolts/stud like Mark mentioned. The TCS setup uses both hard lines and rubber hoses at the ends. I have the factory original setup on my L34 car and can get you a picture but I may not be able to get to it till Saturday.
Scott Kiehne
1970 SS/L78 *Concours frame-off restoration in 2012* Classic Copper & Saddle Interior, matching #'s, 4:10 gears. Owned since 1991
See photos of my L78 Restoration process....
http://www.facebook.com/media/set/?s...3&l=49999673f6
70 SS/L78 is online now   Reply With Quote
Old 08-24-2011, 11:10:04 AM   #6
Airborne
Airborne's Avatar
Scott that would be freakin' awesome. I will wait until I see the pics to order then. Thanks a ton!
George S. Patton
Old 08-24-2011, 11:24:57 AM   #7
flowjoe
I have both TCS solenoids here - you have a PM
Camaros
'67 LA V8 Convertible, Butternut Yellow
'69 NOR Z/28, Yellow w/black stripes - X-77
'69 LA SS 350, Fathom Green
'69 LA Z/28, Daytona Yellow
'70 LA Z/28, Daytona Yellow
'71 LA RS/SS, Nevada Silver
'71 LA SC, Green
Pontiacs
'67 Firebird convertible
'69 GTO - Triple black, 50,000 miles
Corvettes
'70 LT-1, T-top, 4spd, Bridgehampton Blue
'82 T-top, white
flowjoe is offline   Reply With Quote
Old 08-24-2011, 12:11:02 PM   #8
Airborne
Airborne's Avatar
Sounds good. Reply sent for the BB one...
George S. Patton
Old 08-24-2011, 12:47:27 PM   #9
boardog
the parts place has the solenoid and i sent inline a set of original metal lines last year and they should now have them in the cat.
original pic
repo parts
Ken's
Automobile
Restoration
Service
boardog is offline   Reply With Quote
Old 08-24-2011, 02:28:49 PM   #10
Smokey34
Hey Airborne, Didn't see anyone mention it yet, but the green wires go to this switch that installs in the passenger side head. - Not sure if any of the parts places sell a reproduction, or maybe ever Autozone..., but I would definitely stay away from the JoParts seller who has these on ebay. -
Good Luck !
1970 SS/396
1991 Z28/5.7
1999 Z28
Smokey34 is offline   Reply With Quote
Old 08-24-2011, 04:17:10 PM   #11
Airborne
Airborne's Avatar
Smokey, what the heck is that? I'm going to have to go look at my car again. I'm hoping they didn't take that out or there is a hole somewhere. Where is this thing at?
Once again a thing I thought would be quick and simple is turning into some serious fun time.
George S. Patton
Old 08-24-2011, 04:40:13 PM   #12
boardog
pass side cyl. head
Ken's
Automobile
Restoration
Service
Old 08-24-2011, 04:47:40 PM   #13
70 SS/L78
The above picture in post 10 is the TCS temp sensor that screws into the cylinder head on the passenger side (same way as the engine temp sensor on the drivers side). It's all part of the worthless TCS system that chevrolet used. Somewhere on the net I found a really good article that explains in detail how the whole system operates..... I'll see if I can find it again.
Scott Kiehne
Old 08-24-2011, 04:48:20 PM   #14
Smokey34
Hey Airborne, Take a look at the bottom pic in Boardog's ( boardog and Scott beat me to it ) "1st" post, If you look directly to the right of the dipstick, that's it. In Boardog's pic, you can even see the green wires running to it. I know I've seen some of these cars with large plugs screwed into the hole. - I think it's just a temperature switch, but I'm really not sure what exactly this thing does. -
Take Care !
1970 SS/396
1991 Z28/5.7
1999 Z28
Old 08-24-2011, 05:18:08 PM   #15
70 RS/Z28
70 RS/Z28's Avatar
Carl
70 RS/Z28 is offline   Reply With Quote
