Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 08-03-2011, 12:54:06 PM   #1
Dmystix
Edelbrock 1406 600 CFM Fuel Pressure-Electric Pump?
I have Edelbrock 1406 with an Edelbrock manual pump, stock lines, tank, etc.
When I would run the car in hotter temps, mid 80s, it would lay over just past the 1000' mark. I want to add an electric pump just for this. Cooler temps it pulls OK. Right now I don't want to go to an electric only, or some other mech pump. I'm looking at 2 Carters, one is 4-6 PSI, the other is 6-8 PSI. Trying to figure out which would be better for the carb. I don't want to get into regulator, etc. right now. I have Holley blues, black, AN lines, cells, return and deadhead regs, etc., don't want to get into all that, on this car.
This is a mild 350, maybe 300 hp, TH350, 3:73s, DRs. Just want to add a regulated pump for now, while the temps are up.
I remember a thread on here a while back about electric/mech pump combo, couldn't find it.
Dmystix is offline   Reply With Quote
Old 08-03-2011, 10:02:23 PM   #2
Pfrederiksen
6-8 is getting to the top end of what an eddy will tolerate on the needle and seat. Its strange you are having problems with a mech pump on a mild build?
Sure you don't have something else going on?
P
Pfrederiksen is offline   Reply With Quote
Old 08-03-2011, 10:30:46 PM   #3
Damon
You want the Carter street pump (4-6 PSI). You really don't need or want much pressure if you're just using it as a booster for a mechanical pump up front.
I will warn you that the Carter pumps are noisy SOBs. Even if you use the rubber isolator grommets. A Holley Red is almost silent by comparison. But it's also pushing about 7 PSI.
A mechanical pump can SLIGHTLY reduce the pressure of the electric pump. But only slightly. It doesn't take much pressure to unseat the one-way valves in the pump and push on through it. I mean 1 PSI drop at most through the mechanical pump's valves.
1990 454SS pickup. Sold, but I think she found herself a good home.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid-high 12s on street rubber, bottom 12s on DRs with the trans left to shift for itself. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
Old 08-04-2011, 04:42:03 AM   #4
night rider
I would go with a deadhead reg. I have used carter arb and edelbrock carbs for 13-14 years and I tell you right now even alot of STOCK mech. fuel pumps pushes the needles on these carbs.
5.5 psi is the very MAX pressure before the needles start moving out of seats.
I always put a deadhead reg with the eddy carbs and sewt pressure to 5.0 to 5.25 psi
I think that 4-6 psi carter pump runniung through mech. pump may even be alittle too much pressure for these carbs
1988 Camaro -
10.34:1 355, Brodix IK200 heads, 249/252@.050" .570"/.579" lift solid cam, holley 4150 HP 750, th-400, 3500 stall, ford 9" 3.89 gear
Vid clip of my 1988 camaro idling and reving.. New engine combo
http://www.youtube.com/watch?v=a6kfmy4IQQI
night rider is online now   Reply With Quote
Old 08-04-2011, 08:02:37 AM   #5
My73LT
Got that right. Anything more then 5.5 is pushing it on an Eddy carb.
I'd suggest trying to index your banjo inlet fitting if you're using one. I found mine restricted fuel flow into the carb. A little time with a dremel adjusting the fitting really helped. it sounds like your carb is eventually getting sucked dry, and adjusting the fitting may give you what you need for next to nothing.
72 SS/RS/LS, currently under construction
My73LT is offline   Reply With Quote
Old 08-04-2011, 11:41:33 AM   #6
Dmystix
Here's the banjo
Wouldn't the straight shot of one of these be better then the banjo's 90??
Probably have to break down and go for the reg, gauge, etc.
Any recomendations on a pump?
I've got a new Blue on the shelf, but would think something in the 7psi would be better to turn down to the 5 range, rather than the Blue's 14psi.
Old 08-04-2011, 09:37:22 PM   #7
My73LT
The straight shot is better, but doesn't fit with a drop base air cleaner that most of us have to use. Clocking the inside/threaded fitting so it's inlet is directly across from the external fittings inlet helped me. I had to open up the inside fitting, add a gasket or two, and adjust where it pointed. It was cheaper then a fuel pump.
