Old 07-28-2011, 07:45:16 PM   #1
Jfannin
What size fitting on 79 rear brake line that attaches to prop valve?
I am installing a Wilwood valve but evidently made an error on the adapter to link in the rear line. I have a 9/16 x 20 female going into the valve, and I thought the rear line male fitting was that size, but it's smaller.
Jfannin is offline   Reply With Quote
Old 07-28-2011, 10:40:49 PM   #2
Skip Fix
I have a short line I used with that fitting on it that must be a factory line maybe MC to prop valve of my 79-had the other fitting the same as a normal 1/4 line fitting. Pretty sure the other rear line going into the prop valve from the rear end is large also as I had to use two adapters to get it down to the normal 1/4 line fitting size for my adjustable prop valve
Skip Fix
1978 Trans Am 10.99@ 124 pump gas 455
1979 Camaro 383 soon to get a 500" Pontiac motor 695 HP
1981 Trans Am 400,Turbo 301 on a stand
2004 GTO
1965 GTO BIG project
1964 Impala SS 409/470ci stroker project 604 HP
Skip Fix is offline   Reply With Quote
Old 07-29-2011, 12:16:13 AM   #3
Personal_Aviator
Check out these guys. Most auto parts stores should be able to get their stuff.
http://catalog.fmsiinc.com/category/brake-system?&bc=100|1001
1980 Camaro
383 SB
TH350
Full Roller Valvetrain Conversion
Performer RPM Cam and Heads
http://www.nastyz28.com/forum/showthread.php?t=186898
Personal_Aviator is offline   Reply With Quote
Old 07-29-2011, 03:08:33 AM   #4
wardracing
i had the exact same problem, i work at advance auto parts and we had the adapter fitting in stock just go to your local parts store and tell them what you need!
wardracing is offline   Reply With Quote
Old 07-29-2011, 09:13:13 AM   #5
jamieg285
For the factory prop valve/MC combo (figure in brackets is line size):
Master Cylinder Out (Front) 1/2 - 20 (3/16)
to
Prop 1/2 - 20 (3/16)
to
Front (x2) 3/8 - 24 (3/16)
Master Cylinder Out (Rear) 9/16 - 18(1/4)
to
Prop 7/16 - 24 (1/4)
to
Rear 9/16 - 18 (1/4)
Not sure if that all carries over to Wilwood though.
Regards,
Jamie
1979 Camaro - 305 SBC, 416 heads, 1850 Holley carb, 1 5/8 Stainless headers, 2.5" Pypes X-pipe system
www.mfatw.com/WD 'WhiteDream' 79 Camaro Website
http://www.mkb.cc
jamieg285 is offline   Reply With Quote
Old 07-29-2011, 11:41:51 AM   #6
Skip Fix
Alot of the Wilwood I've seen have the same 9/16 and 1/2 listed,even their Mopar style.
Skip Fix
2004 GTO
Old 07-30-2011, 07:56:12 PM   #7
Skaal-tel 79
Skaal-tel 79's Avatar
stock rear end line is 9/16, can't tell ya the pitch off hand. Why do you need an adapter? You should be able to purchase a tube nut that adapts 1/4 tube to 9/16 sae flare. I've never seen them in a variety of thread pitches.
Maybe you're trying an NPT fitting?
Arte et Marte
Open Header video
ZZ4 short block, wiseco 10:1 forged under brodix IK200s w/ rpm air gap, 670 street avenger, 1 3/4" hooker super comps, pypes X 2.5" Pro-V, 200-4R, quicksilver shifter, 3.73 w/ posi.
My project thread
Skaal-tel 79 is offline   Reply With Quote
Old 08-01-2011, 08:08:43 AM   #8
Jfannin
Thanks everyone - I did determine it is indeed a 9/16 x 18. What I'm doing is tying in the Wilwood adjustable valve to my rears. I have everything tied in up to the stock rear hard line, just under the master. I had the hydraulic shop make a line from the Wilwood that ends with the identical male, hoping to find a double female union to tie my two 9/16 x 18 males together, but I have searched and searched all over and can't find one? I checked advance, autozone, and o'reilly on line with no luck. I've also checked several brake parts websites and it doesn't look like such a union exists??? I'd appreciate any help! This is the last part I need to get the car on the road.
Old 08-01-2011, 09:39:21 AM   #9
Rene Melten
Rene Melten's Avatar
Your looking for a 1/4" inverted flare union/ coupling? Try a plumbing supplier... they do make them, here's an example...http://www.fastfittings.com/product/12024
'73rs 350 .060 over,Super T-10,3.42 Posi,
AFR Heads, 670 Street Avenger, MSD, Hooker,
10 Bolt, Wilwood/GM 4 wheel disc
http://s930.photobucket.com/user/73r...423-1.jpg.html
Rene Melten is offline   Reply With Quote
Old 08-01-2011, 09:54:32 AM   #10
Jfannin
Thanks Rene - I also just found this morning a part number BQ119 frin BrakeQuip but it looks like they only deal with dealers. I will check out the plumbing stores and also give BrakeQuip a call.
Old 08-01-2011, 02:09:16 PM   #11
Jfannin
Finally found the part number BQ119 (9/16 x 18 for 1/4 line double female union) at Clarkville Fasteners in TN. $2.91 each and they will take orders over the phone and mail out. Just thought I'd let you guys know. Thanks for all the responses. Hopefully this will end my brake restoration chapter and we can move on to the inner doors...
