Old 06-28-2011, 09:11:13 AM   #1
janis80z28
suggestions on oil weights
i have a 1985 rebuilt 350, from the block up. its now a 383 stroker. What weight oil do you recommend?
it has 700 miles on the motor already.
janis80z28 is offline   Reply With Quote
Old 06-28-2011, 10:34:41 AM   #2
BondoSpecial
BondoSpecial's Avatar
do you know what the bearing clearances are? Assuming it has normal (1.5-2 thousandth) clearances I would just run 10W-30.
Steven H. www.carfap.com
2011 Infiniti M37X, 2004 Ford F250 6.8 V10 6 speed manual 4x4, 2000 BMW M5, 1999 C1500, 1994 Town Car, 1976 Jeep DJ5
BondoSpecial is offline   Reply With Quote
Old 06-28-2011, 11:12:27 AM   #3
Cardinal
10W30 synthetic.
Cardinal
Cardinal is offline   Reply With Quote
Old 06-28-2011, 12:13:43 PM   #4
SupplySgt
SupplySgt's Avatar
Originally Posted by Cardinal
10W30 synthetic.
Better know for sure that there are no cork gaskets. I would guess that there aren't but I would rather know for absolute sure. Synthetic is death to cork gaskets. That's the main reason I haven't started running synthetic in my 73. Once I am able to pull the motor and replace all the gaskets and everything I will start running synthetic. You did give the weight that I was gonna recommend though.
'73 Z28 350/TKO 600. Dream car that fell into my lap!
'78 base model Vortec 350/TH350. Future RS clone.
They tend to call me Sarge
Originally Posted by Marks71BB
I be coon killahh
Originally Posted by K5JMP
that's the money we could be saving IF we had nationwide carry permits....
-KJ4CLI-
SupplySgt is offline   Reply With Quote
Old 06-28-2011, 01:48:28 PM   #5
janis80z28
I did do a bit more digging. 10w 30 looks like the one. BUT I see people saying to add ZDDP. What do you guys think of adding this stuff to the oil?
not doing synthetic for now.
Old 06-28-2011, 01:57:35 PM   #6
hhott71
hhott71's Avatar
Whatever gives you atleast 20lbs of pressure at idle, in gear with a hot engine.
Could be 5w-20
could be 20w-50
Start with 10w-30 and see...
Your 1500 rpm and up pressure will probably be 45 lbs and up on any of the oils.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 06-28-2011, 02:42:19 PM   #7
ProStreet383
ProStreet383's Avatar
1976 mini tubbed, 8 point roll bar, kirkey pro street seats and 5 point harness, 385 with cola crank, Scat pro comp 6" rods, probe pistons at 10.83:1 compression, Custom bullet solid roller cam, brodix dragon slayer heads, victor jr topped with Pro-Systems 950.
ProStreet383 is offline   Reply With Quote
Old 06-28-2011, 05:00:47 PM   #8
NYH1
Could be 5w-20
could be 20w-50
I agree. I'm getting 18 to 20 psi. at warm idle with both 5W-30 or 10W-30. The main difference between the two is at cold start up. With 5W-30 my oil pressure is right at 60 psi. and with 10W-30 it's 65 psi. My oil pressure drops a little quicker with 5W-30 as my engine gets up to operating temperature. Once it's up to operating temperature, they're the same.
At cruising speeds my oil pressure is anywhere between 40 and 60 psi. depending on my engine speed.
'78 Camaro, mild Vortec head 385 stroker motor, 9.1:1 comp., 6" rods, Lunati Voodoo 262/268 hyd. flat tap. cam, Performer RPM Intake, 650 AVS carb, 1 5/8" full len. Hedman Headers, 2 1/2" full len. Flowmaster Dual Exh. Sys. w/Trans. Flow Muffler. TH350 Coan 11" 2600 stall conv., 10 bolt 3.42's Duragrip Posi, '70-'79 Z28 5 spoke mag wheels.
NYH1 is offline   Reply With Quote
Old 06-28-2011, 05:29:26 PM   #9
Cardinal
Synthetic is murder on cork gaskets? I ran Mobil 1 in my '79 Olds with a 300 hp 350 SBC for 86K miles and it never leaked a drop of oil out the valve covers.
Cardinal
Old 06-28-2011, 06:13:09 PM   #10
ProStreet383
It is just an old wives tail. The real proven truth is that dino oil gums up and sludges up much easier than synthetic. What this does to an engine that is getting older and getting miles on it is form deposits around already deteriorating gaskets and keeps them from leaking. A switch to synthetic starts cleaning up those deposits and suddenly a leak starts and the synthetic gets the blame. Synthetic oil itself does not deteriorate any type of gasket material.
P.S. To anybody interested I get dealer pricing on all amsoil products. I am not a dealer. I have a business account with them for my lawn service. I use amsoil in everything because I get a good price on it and it truly is great products. If anybody wants I can get you dealer pricing on anything amsoil sells. Just PM me. That Z-Rod oil i posted above in over $9 a quart street price. It is about $7 my price which is still high but it is a "REAL" synthetic Group 4 base stock.
Old 06-28-2011, 07:49:04 PM   #11
455 Formula
I have never ran anything but Valvoline 20/50 racing. Works great in our climate, which ranges form 32°F+ to 115°F, plus has ZDDP...Robert
"If I had better junk in my garage, I know I could go faster....."
The Pontiac 413 Is In The Car!!!!:
http://www.youtube.com/user/The10851Man?feature=mhee
455 Formula is offline   Reply With Quote
Old 06-28-2011, 10:37:43 PM   #12
GoldenOne7710
GoldenOne7710's Avatar
Originally Posted by 455 Formula
I have never ran anything but Valvoline 20/50 racing. Works great in our climate, which ranges form 32F+ to 115F, plus has ZDDP...Robert
This guy is on to something. You should take your bearing tolerances into account....but ALSO the average climate you live in. Ever looked in a vehicle's owner's manual and saw a temperature chart in the recommended oil section? It's there for a reason.
-Andy
1979 Z/28
NRA Life Member
GeorgiaCarry.org Member
GeorgiaPacking.org Member
ΜOΛΩΝ ΛΑΒE
Equal Opportunity Offender
GoldenOne7710 is offline   Reply With Quote
Old 06-29-2011, 08:10:28 PM   #13
SavingTheBird76
15 w 40 Diesel for older engine specs.
71 Pontiac Le Mans 350
73 Buick Centurion ragtop 455
74 Chevy El Camino 350
76 Pontiac Trans Am 455
97 Honda Valkyrie
69 396 Building....
SavingTheBird76 is offline   Reply With Quote
Old 06-29-2011, 10:56:56 PM   #14
Todd80Z28
Don't tell my cork gaskets that. They've not leaked in 9+ years.
The front and rear main seals, on the other hand...
hhott's on the oil suggestion, too. I used to always run mine with 10W30 (Mobil1 Syn), but then it started to get a little noisier (very subtle) over time. I switched to 10W40 (still Mobil1 Syn), and it has quieted down quite a bit. I couldn't tell you what my pressure is- no gauge, just the idiot light. If it goes away and I grenade the engine, then new engine for me- YAY!
Todd80Z28 is offline   Reply With Quote
