Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 06-08-2011, 01:14:38 AM   #1
81silver1
Aerohead racing
has anybody tried the heads from aerohead racing? pretty curious about them for a budget $400 for a set check them out aeroheadracing.com
81silver1 is offline   Reply With Quote
Old 06-09-2011, 01:23:05 AM   #2
rustbucket79
Probably fine, but you're looking at factory smogger castings rebuilt with larger valves, etc. I'm going to take a wild guess and say their 65 cc castings are based on 305 heads.
If you're looking for additional power, you'll be $$$ ahead going with either Vortec heads or something like the E streets or the RHS vortec replacements.
Vids of the car: http://www.youtube.com/watch?v=Fb39m4ToP50
rustbucket79 is offline   Reply With Quote
Old 06-12-2011, 05:46:51 PM   #3
dallam2
Years ago I bought a set of heads from them. It seems like I paid around 260 dollars plus about 25 dollars shipping. The heads were the old 993 non-sought after smoggers but they were nicely redone with larger valves and good seals.
I still have them on my current 1981 4 speed Camaro but recently I did a bit of home porting and such to them and had them locally cleaned and resealed for about 125 dollars. I have a XE 268 cam installed (nice cam) and am running cheap cast flat top pistons which makes about 9 to one compression and headers. I must say the car definitely buggies and has almost alarming mid range power.
The shop has been around forever and if you want to save a buck or two and still go fast, you can and you won't be disappointed with what they have to offer. Give the shop a call like I did years ago (1990) and you can go from there. Good luck
dallam2 is offline   Reply With Quote
Old 06-15-2011, 01:24:24 PM   #4
AJ_72
IIRC, they sell the Iron Eagle S/S heads.
Those flow nearly as much as Vortec heads, and according to CHP, they made about the same HP and Torque as Vortec heads, on a 383 using a Comp Cams Xtreme Energy 274H cam.
Look at, not only the peak numbers, but the average numbers.
Here are the results of the Dart heads.
http://www.chevyhiperformance.com/te...ad_racing.html
Then the Vortec Heads.
http://www.chevyhiperformance.com/te...in_dickey.html
->Click Here<- for an exhaust clip of my car.
May your nose never itch while you are painting.
AJ_72 is offline   Reply With Quote
