Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Old 06-05-2011, 09:55:39 PM   #1
cheersz28
Rewiring my 73 any suggestions
I'm looking to rewire my 73 and I've been looking at AWW or painless. I'm going with Autometer gauges in the dash.
cheersz28 is offline   Reply With Quote
Old 06-05-2011, 10:00:57 PM   #2
Dewey70
I am about finished with re-wiring my 70 with an AAW. A very nice kit with good instructions and great tech support. Baring a total meltdown once I put the key in the ignition, I highly recommend AAW.
I sat on the kit for 6 months intimidated by the project, but have found it to be rather easy.
Good luck.
70' Z28, Memphis,TN
Dewey70 is offline   Reply With Quote
Old 06-05-2011, 10:06:05 PM   #3
krabben1
krabben1's Avatar
Ive got an AAW classic update kit half installed and I like it also.Easy to follow instructions and they give you much more wire than you need to run it how you want.
Gen VI 454, Autogear M-22 W, Moser 12Bolt
Hurt-Johnny Cash
http://www.youtube.com/watch?v=McV7pjwVFbE
krabben1 is online now   Reply With Quote
Old 06-08-2011, 10:09:20 PM   #4
amargari
AAW all the way.
1973 Type LT/RS
http://www.apiem.com/camaro
amargari is online now   Reply With Quote
Old 06-08-2011, 10:14:05 PM   #5
K5JMP's Avatar
solder and heatshrink tube...
every connection gets soldered.
K5JMP is online now   Reply With Quote
Old 06-09-2011, 02:43:25 AM   #6
franks70camaro
Good luck.
dewey how much was the kit you used for ur 70 camaro sounds like what im looking for as well i need to re wire my hole restoratrion???
i wanna go fast lol
franks70camaro is offline   Reply With Quote
Old 06-09-2011, 08:15:02 AM   #7
Dewey70
About 8 months ago I think I paid about $560 for their "Classic Update kit" (for use potentially more modern accessories)(I think the factory match kit is actually much more expensive). It is highly recommended that you buy/rent their GM crimping tools for $200/$50 which work real nicely.
Good luck.
70' Z28, Memphis,TN
Old 06-09-2011, 09:37:51 AM   #8
Patrick73RS
Patrick73RS's Avatar
Do you want original wiring or not?
Patrick73RS is online now   Reply With Quote
Old 06-09-2011, 05:18:53 PM   #9
franks70camaro
to me doesnt matter if i go origanal or not just whant something clean and easy as im not a electrical guru lol
i wanna go fast lol
Old 06-09-2011, 08:11:03 PM   #10
Patrick73RS
Budget?
Old 06-10-2011, 08:16:08 AM   #11
franks70camaro
nothing to outa this world mayb as high as 400to 475
i wanna go fast lol
Old 06-10-2011, 10:28:00 AM   #12
Rich Schmidt
When you start running the wire,I found something that I really like. I bought these "self soldering connectors". Basically they look like regulare crimp connectors,but they have clear heat shrink over them. You out them on the wires,heat them with a cigarette lighter or something similar,you can see the solder flow around the wore as the shrink squeezes down. You can even out an extra layer of heat shrink over them if you like. I have them on the 74 that I just rewired. I took the 2 power leads that go to the battery stud on the starter and moved them up to the firewall and installed an 80 amp circuit breaker in place of the fuseable link. I used the self soldering connectors on the big wires going to the breaker into the car and to the battery. It is very neat,not near the headers,and still protected. Good luck.
1973 Camaro hot rod owned since 1989 runs high 12's. Mild 408 small block,th350,3.08 gears,ice cold a/c pumpin system ect.
1973 Firebird owned since 1994 runs mid 10's on motor and mid 9's on a 250 shot. BBC 439 2 speed,4.88 12 bolt,3600# full street car.
2011 Camaro RS,Jewel Tint.
2003 Silverado HD2500 and Wife's 2004 Malibu Maxx. Keeping my Family ALL GM!!!
Rich Schmidt is offline   Reply With Quote
