03-28-2011, 04:55:18 AM
#1
Have a question about battery wire from trunk
I am relocating my battery. I have a 1 gauge power wire that I got for free from a parts car I have. Will this be ok to run to my starter from the battery? How exactly should I run this setup. Never hooked one up in the trunk before.
03-28-2011, 10:17:38 PM
#2
03-29-2011, 12:42:13 AM
#3
Thanks man
,,read the nasty thread and it doesnt tell me anything about how to hook it up.
I am really looking for a diagram of how to wire everything the safest way possible without too many wires
03-29-2011, 09:44:58 PM
#4
The other thread is just 1 to watch as it seems to be the same thing. Just in case you don't get replies. The mad electric link should give you enough info on HOW to wire it up to keep from catching fire. 1st....what is your electrical "know how"? NFC?....mediocra?....verygood? (No F*king Clue)
Kinda gotta know How to detailed to get here. Could write 25 pages so my 7yr old could do it....or write 1 page for somebody that just needs to know which wire to cut from the ignition switch and how to run the atlernator wire back to the trunk?
03-30-2011, 03:26:38 AM
#6
Thanks Twisted!
Yea Fbird I just need to know what wire to take back etc
03-30-2011, 08:54:59 AM
#7
NO you need two 1 gauge cables.
You must ground the battery directly to the engine block.
You can actually use 4 gauge on both cables.
It doesn't matter how well you ground the engine to the frame and the battery to the frame, it won't be enough. Run a dedicated Ground cable too.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
04-02-2011, 07:29:16 AM
#8
I would have to respectfully disagree! While you can NOT use the little braided wire from GM to ground your engine for this application, you certainly do NOT want or need another 20ft of 1 gauge cable. A simple 1 gauge cable to ground the engine to the frame and a 1gauge cable to ground the batt to the frame.
http://www.madelectrical.com/catalog/tm-1.shtml
The battery ground (NEG) is connected to the car body at the rear. And up front, another short length 1/0 cable connects from body to the engine. This system uses the car body for the long intermediate length of the NEG side of the system all the way to the engine. (It’s actually more efficient than routing a heavy gauge cable all the way forward to the engine.)
The wire you are wanting to run to the trunk would be the "excite/start" wire from the ignition switch ----> the ford solenoid in the trunk. ALSO u will need to run a charging wire from the main harness to the +battery or battery side of new solenoid. This 8 gauge wire MUST have a FUSE...again chat with the guy at mad and read his stuff.
04-02-2011, 04:50:08 PM
#9
Hey thanks so much fbird
07-29-2011, 01:44:53 PM
#10
About to finally get this wired up. Just wanted some clarification. So I will run my 0 gauge welding wire from the battery to the starter, ground the engine the frame up front, ground the battery to the frame out back, and two 8 gauge wires from the front to theback- one from the harness to the battery for a charging wire and one as the excite wire to the ford solenoid. Does this sound correct? Anyone have a diagram of how to connect it all the the solenoid? Thanks for all the help guys!
1972 True Z28
QA1 Coilovers
Trz Control Arms
Summit Warriors
Lowered 2.5"
Hooker 1-7/8 headers
Pypes X pipe & Violators
02 TA Seats
Strange Brakes
Hurst Quarter Stick
07-29-2011, 02:46:21 PM
#11
You can put a power distribution Post/block on the firewall above the starter. Run your Battery to it. Then run from it to the starter. Can charge to that post and not run the charging wire all the way back to the trunk.
You can run the power wires that normally hook to the starter to the post/block also. That way you only have the one power cable going to the starter. And 1 solenoid wire.
You can look at the Madelectric link above. I also posted some pics a few days ago on this same subject.
EDIT: here is my post with the pics in it. http://www.nastyz28.com/forum/showpo...72&postcount=5
07-29-2011, 04:11:52 PM
#12
Thanks Hoot! So I only need the one wire coming up from the trunk? And take it from the battery to the distribution block?
1972 True Z28
QA1 Coilovers
Trz Control Arms
Summit Warriors
Lowered 2.5"
02 TA Seats
Strange Brakes
Hurst Quarter Stick
07-29-2011, 04:51:58 PM
#13
yup. Then you can run smaller from the post to the starter if you want. Since it is a short distance. Just think of the distribution block as a remote battery post.
07-29-2011, 07:41:21 PM
#14
yeah my car starts twice as quick with the ground going from the battery to frame rail in the rear, then nice ground from engine to frame..Along with the other good grounds needed..Neglected grounds are horrible..Theres a pic in my build of the rear mounted selenoid, breaker for alt wire, fusible links.and whatnot if you need them..
07-29-2011, 08:05:14 PM
#15
Awesome. Thanks guys I appreciate it
1972 True Z28
QA1 Coilovers
Trz Control Arms
Summit Warriors
Lowered 2.5"
02 TA Seats
Strange Brakes
Hurst Quarter Stick
| Thread Tools |
| Display Modes |
Linear Mode
