Old 03-22-2011, 08:51:21 PM   #1
Rich Schmidt
My job installing entire roof and structure
I am replacing the entire roof including the inner structure and the A-pillars on my 73. I figured I would show how I was doing it so anybody interested could see what holds the roof together,and how to swap stuff out.
I am also installing new full 1/4's at the same time,so it will allow me to show how everything attaches together. I am drilling out and splitting the spot welds that hold the inner 1/4 structure to the inner roof structure,and simply removing the roof from the car good car with the roof skin and chunks of 1/4 panel attached. The donor roof was cut with lots of 1/4 panel and inner 1/4 structure attached,and everything was seperated on the shop floor after the roof was off.
I cut the A pillars on the donor roof way down into the cowl area,because I wanted to have the luxury of making my final cuts on the shop floor where the metal wouldnt be stressed from the weight of the roof dangling from it. I plan on cutting right next to the seams where the factory overlapped panels right at the base of the pillar,and butt welding it at the cuts. It wont technically be a factory job,but the welds will be consealed since the factory blobs lots of seam sealer on the lap welds. I am thinking that I will try and sister it up from the inside by using 1/8" plate cut to slide into the pillar,then drilling thru the pillar and plug welding in my reinforcement plates. I also plan on leaving a 1/8" gap at the joint so when I weld it will penetrate the multiple layers of metal. I will include many pics of that part of the job.
I braced the car up with angle iron. I spanned the door on an angle from midway up the inner 1/4 structure to directly over the bracket that holds the dashboard brace in. I then welded an angle iron across in between the side supports at the back edge of the door opening. From there I welded 2 uprights that just lay against the inner roof structure,then I welded to bars from those uprights to the package tray to keep the uprights and cross bar from flexing. I measured the distances side to side from each creoss bar to the ridges in the center of the roof structure as well as to the back edge of the roof. The uprights will serve to hold the new roof at the correct height and the measurements will help me make sure it is located in the right spot.
Here are some pictures.
The bracing
Here is the inside of the donor roof. The C pilar area is all ready to be welded in place,all traces of the donor car are removed clean,the edges where the welds were cut are hammered flat. Next step is to start trimming the A pillars
1973 Camaro hot rod owned since 1989 runs high 12's. Mild 408 small block,th350,3.08 gears,ice cold a/c pumpin system ect.
1973 Firebird owned since 1994 runs mid 10's on motor and mid 9's on a 250 shot. BBC 439 2 speed,4.88 12 bolt,3600# full street car.
2011 Camaro RS,Jewel Tint.
2003 Silverado HD2500 and Wife's 2004 Malibu Maxx. Keeping my Family ALL GM!!!
Rich Schmidt is offline   Reply With Quote
Old 03-22-2011, 09:09:22 PM   #2
Rich Schmidt
The inside all cleaned. The roof and structure are attached to the car and each other at 2 different points. The very outer edge is both the roof skin and roof structure welded together,and the top edge of the 1/4 panel is welded to the INSIDE of this flange. The welds that are inboard(alongside the 2 curved cutouts)only attach to the inner 1/4 panel structure. Here are 2 pics of a roof and structure all cleaned at the C pillar.
Inside view
Outside view
The A pillar cut with extra material which will be cleaned off.
Old 03-23-2011, 07:33:21 PM   #3
Rich Schmidt
Well a little each day. I got the roof off the good car. The inner 1/4 structures are real nice as are the tops of the rockers. Now I have to do all the delicate trimming to make it go together nice nice.
Old 03-23-2011, 07:50:56 PM   #4
80-z28
That looks like alot of work. Good luck.
Original 350 standard bore
Flat top four valve relief pistons
Brodix IK180 64cc heads
Comp XE274H cam
Performer RPM air-gap intake
Quick Fuel SS680VS carb.
TCI breakaway converter
TH350 trans
Original 3:42 rear end
80-z28 is offline   Reply With Quote
Old 03-23-2011, 08:27:32 PM   #5
Rich Schmidt
Thanks. Just the roof alone is a good bit of work. It looks even worse because I cut the 1/4's off and will be axing the outer wheelhouses next. At this point I need to stop removing panels and get the roof back on. Tommorrow will be a busy day for prepping the car for the roof.
Old 03-24-2011, 03:13:24 AM   #6
78cam454
doing a good job so far as it looks. I cant wait to see the finished job
78cam454 is offline   Reply With Quote
Old 03-24-2011, 03:39:38 AM   #7
MrRedfish
MrRedfish's Avatar
a whole lot of work
71 Z-28 with a 555 F-2 procharged BBC{hoping for 1250-1400 hp} GET DOWN GET DOWN
MrRedfish is offline   Reply With Quote
Old 03-24-2011, 07:24:33 AM   #8
sceld71
Been there done that, well sorta... I paid a local shop. I'm glad I did and wish I had skills like your's. Good luck.
sceld71 is online now   Reply With Quote
Old 03-24-2011, 10:52:40 AM   #9
POS71RS
POS71RS's Avatar
Good write so far. Keep up the good work and get-r-dun.. I added this to the body-work sticky list.
Old 03-24-2011, 02:43:37 PM   #10
78cam454
Nice, may need this one day if i decide to do an early second gen after my 78
Old 03-24-2011, 09:17:00 PM   #11
earlysecond
Good work Rich.
Check the progress on the second re-incarnation of the same '70 sport coupe (in 6 years)at: Click Here
earlysecond is offline   Reply With Quote
Old 08-26-2011, 05:06:06 PM   #12
papapayne
is the roof on yet!
papapayne is offline   Reply With Quote
Old 08-26-2011, 05:18:16 PM   #13
76 camaro car 1
Just becouse I'm courious,Why did you replace the roof? Did it have a sun roof,dents,rust?
Save a life,become an organ donor. ______________ Support the wounded warrior project.
76 camaro car 1 is offline   Reply With Quote
Old 08-26-2011, 06:22:48 PM   #14
2nd gen man
i really wish i had the body skills you guys have on here.
your doing a great job.
good luck....
2nd gen man is offline   Reply With Quote
Old 08-26-2011, 06:43:11 PM   #15
my24ktrat
...Had the roof replaced on my 78 Z , almost the same way , they split the front pillars in 1/2 the long way ,and used the factory seam in the rear , over 15 yrs later , new owner , no cracks ,lol . Mine had the garbage Hurst Hatches, which leaked, no more , DC
my24ktrat is offline   Reply With Quote
