Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 03-08-2011, 06:07:47 PM   #1
Enroute
Question Vortec 400 SBC - Hyd. Roller Cam specs req'd
So it seems my project has taken yet another turn...a turn for better.
I'm finally building what I know my heavy 81Z needs... a 400 SBC!
Basic parts list:
Stock 2-bolt 400 block @ 4.125" bore. Will keep overbore to minimum.
Stock 400 crank.
5.7" rods.
Vortec heads. Factory iron. Reworked to handle high lift roller camshaft.
Pistons: Will be forged. D-dish (or similar) to get desired C.R.
GMPP dual plane Vortec intake. Q-jet carb. Headers.
Build Specs:
9.5 - 10.0 Comp Ratio.
0.045" - 0.055" quench height.
5800-6000 rpm MAX.
Street driven car only.
3.42 gears with 700R4 and 2500 stall with lockup (existing setup).
Characteristics that Hydraulic Roller Camshaft must be/create:
  1. Camshaft will be hydraulic roller (retrofit).
  2. Lifters will be retrofit type.
  3. Needs good vacuum for power brakes.
  4. Good idle. A slightly menacing sound as if it sounds like it's got a stick in it would be cool. But nothing too lopey or crazy.
  5. Car is emissions exempt.
I have done a great deal of searching on this site of owners who have/had a 400 SBC with factory iron Vortec heads. Many of you here have had great success with iron Vortec heads on a 400 SBC. Several user profiles come to mind. The Vortec sticky atop the Engines section has proven invaluable; thanks Dirt!
Many have stated that a 400 will swallow a lot more cam than one would expect when upsizing from a 350. Almost every cam I've seen spec'd out for an iron Vortec 400 was either a hyd. FT or solid FT.
I'm having a hard time specing out a hydraulic roller camshaft for my 400 SBC.
Anyone want to take a kick at the can and recommend/suggest a hydraulic roller cam for my iron headed Vortec 400???
Thanks
Project thread link soon to be updated.
got torque???
Enroute is offline   Reply With Quote
Old 03-08-2011, 06:23:05 PM   #2
hhott71
hhott71's Avatar
The Crane Powermax Part # 119841 Cam is a really good cam.
I have 12-14" of vacuum in a 350 with it.
So in a 400 it will be tamer.
It pulls to 6500 easy in the 350
SPECS:
.539 /.558"
234º / 242º
112º LC
2500-6000 w/6500 valve float (it goes higher with better springs but there isn't really any extra power, especially with Vortecs, up that high)
HP/TQ I have no clue, best times are in Sig.
Any other motor/car answers are in my profile.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 03-08-2011, 10:34:23 PM   #3
rustbucket79
Something like a Comp 270HR would be my choice. Biggest thing with the 383/406's with roller cams is they need considerable rod clearancing. This is one situation where I would highly recommend buying the Scat 2-ICR5700-7/16 rods, they are a Pro Mod copy with a very short capscrew, giving lots of clearance for the cam. (may still need a little grinding) These rods need a full float style piston. (retaining clips for the pins)
Vids of the car: http://www.youtube.com/watch?v=Fb39m4ToP50
rustbucket79 is offline   Reply With Quote
Old 03-08-2011, 11:11:21 PM   #4
DesmoEd
My understanding of vortec's is that they are small runner heads and done at .500 lift so I don't see much point in using a cam beyond that..........
112LSA will keep the idle nice, provide good vacuum, and broaden the tq curve.
I just bought a Howards hyd roller for my 355 - its .501/.509 and 280/292 adv duration (224/230 @ .050) on a 112LSa
"The quality of the kite matters little, success depends upon the man sitting in it"
Manfred von Richthofen - circa 1917
1973 Camaro RS - 355ci, 10.1-1, Perf RPM heads, Howards 280/292 HR, 1.52, Holley 300-36, Holley HP650 DP, MSD, Hedman, M-20, 3:73 posi
1969 Corvette - 360ci, 10.25-1, Perf RPM heads, Comp XR276HR, 1.52, RPM air gap, Holley HP750 DP, MSD, Hooker, TKO600RR, 3:73 posi
DesmoEd is offline   Reply With Quote
Old 03-09-2011, 08:44:00 AM   #5
onovakind67
I agree on the Comp HR series. I used a Comp 280HR in my daily driver 406 and it worked extremely well. It's 224°/224° @ .05", .525" lift, about 16" vacuum at idle, phenomenal torque, got 18 mpg on the highway and pushed my 3450# car to 11.75@117 thru the muffs.
Horse sense is the thing a horse has which keeps it from betting on people.
onovakind67 is online now   Reply With Quote
Old 03-09-2011, 10:39:09 PM   #6
1980RS
A small cam on a 106° LCA with a mild duration will make that 406 a stump puller. I have read that vortecs can make as much as 500 lbs. tq. Boys that is Big block tq. in a small package. Remember one thing, A given cam will act smaller in a larger displacement engine.
1980RS is offline   Reply With Quote
Old 03-11-2011, 01:43:11 PM   #7
Enroute
Big block torque out of my small block
This is the motor I have been waiting for.
Thanks for the input.
got torque???
Old 03-11-2011, 03:03:09 PM   #8
BLKnBad71Z
Basic parts list:
Stock 400 crank.
5.7" rods.
Build Specs:
5800-6000 rpm MAX.
Thanks
I have the cam you need. Lunati Voodoo hyd roller-
.535 int / .500 ex Lift
231 int / 239 ex Duration @.050 lift
110 centerline
2400-6200 rpm range
Nice lope at idle. Great all around street cruiser or strip action. Includes cloyes double roller timing chain set too. Only has about 600 miles on it. Also ground on a short base circle for stroker rod clearence. Let me know if your interested. Thanks
Badddd71
BLKnBad71Z is offline   Reply With Quote
Old 03-11-2011, 03:30:28 PM   #9
Enroute
110 centerline
2400-6200 rpm range
PM sent
got torque???
