Old 02-19-2011, 01:50:40 AM   #1
70sbudget
oil pressure sending unit location????
i have a 87 454 out of a suburban and have looked through three different manuals, on the block and CANNOT find the oil pressure sending unit. i am looking for both the water temp and oil pressure units. the only one i can find is on the drivers side head and i am thinking it is the water temp.
where is the oil pressure sending unit??????
so that is why the car show went to comercial!!!!!!!!!!!!
it seemed like a good idea at the time.......
70sbudget is offline   Reply With Quote
Old 02-19-2011, 02:12:39 AM   #2
70sbudget
swerving, thank you. ill pull the new headers to paint and see if thats is the location.
anyone have a pic of a truck block(if they are different)?
Old 02-19-2011, 02:13:14 AM   #3
70sbudget
swerving,,,,,is your other sending unit (water) located in the drivers side head?
Old 02-19-2011, 09:45:30 AM   #4
krabben1
krabben1's Avatar
I had planned on using the stock oil location for mine(454,oil filter boss)then after installing it,had to remove it because of bellcrank interference.Im now going to be relocating it to the small block location,behind the distributor,above tranny.So,if youre running a stick,make sure thats in there as well for fit up.
Gen VI 454, Autogear M-22 W, Moser 12Bolt
67 Chevelle 468,P/G,10 Bolt
My build
http://www.nastyz28.com/forum/showthread.php?t=127870
krabben1 is online now   Reply With Quote
Old 02-19-2011, 11:50:05 AM   #5
theflash
theflash's Avatar
Old 02-19-2011, 12:19:49 PM   #6
old zeder
I don't think he will have the upper block location for the oil sender, that location is only on the new blocks was not there on my 454, he may have to use the lower location near filter
Gone to the dark side, just a nice sweet ride
1971 RS zz502 & TKO 600 5-Speed
2011 2SS/RS LS3 & M6-speed, Hurst Short throw, IOM/Blk Stripe, IO/Blk Interior
LED Tail Lights http://www.youtube.com/watch?v=vs342...015115540.m2ts
Pypes Exhaust http://www.youtube.com/watch?v=u_Aws...223143346.m2ts
old zeder is offline   Reply With Quote
Old 02-19-2011, 02:14:23 PM   #7
kyles_81Z28
on the 350 theres a spot on the back of the intake right beside the distriburtor that i use for my oil press. gauge
kyles_81Z28 is offline   Reply With Quote
Old 02-19-2011, 03:53:16 PM   #8
70sbudget
thanks for the great pics guys!
Old 02-19-2011, 05:27:02 PM   #9
70sbudget
Originally Posted by swerven
Oil pressure port is just above the oil filter.
This a 2 bolt car block. Might look a little different than a truck motor, but the location of the port is the same.
good news, there is a hole in the block in this exact location. the hole is plugged by a 4 point (square) head as opposed to a hex head. what is the best tool to remove this with? i dont want to strip that puppy!
Old 02-20-2011, 01:05:36 AM   #10
jayfire
I went to the hardware store and got some square stock that fit the hole, put it in a socket. Worked like a charm. Might be able to use 3/8" ratchet extension as well.
jayfire is offline   Reply With Quote
Old 02-20-2011, 01:54:00 AM   #11
70sbudget
hmm, well, being that they are male fittings, i think i may buy the tool so i can remove the differenitial fill plug too. thx guys
Old 02-20-2011, 01:58:46 AM   #12
Prototype4342
depending on the size, you can use a ratchet or breaker bar to remove plugs like this. i removed my diff fill plug with a 1/2 inch drive ratchet with no socket on it.
My '81
'81 Camaro: 5.7L '86 350 LT9, Edelbrock Performer Intake man., Edelbrock 600 carb., Drop base air cleaner, unnamed headers, pypes crossflow exhaust, ECP all aluminum radiator, Mark VIII electric fan, PTFB GT suspension, single adjustable AFCO shocks, C/E subframe connectors, 4-speed.
Prototype4342 is offline   Reply With Quote
Old 02-20-2011, 02:05:38 AM   #13
Rene Melten
Rene Melten's Avatar
If this is a protruding plug and a regular wrench doesn't work. Grab as much of the plug you can with small vice grips, even if the the threads show, grab it if you can. Tap the head of the plug with a hammer and loosen slowly. Attempting this little plug is strip it or going to greater measures..proceed with caution.
'73rs 350 .060 over,Super T-10,3.42 Posi,
AFR Heads, 670 Street Avenger, MSD, Hooker,
10 Bolt, Wilwood/GM 4 wheel disc.
http://i930.photobucket.com/albums/a...0.jpg~original
Rene Melten is offline   Reply With Quote
Old 02-20-2011, 04:04:31 PM   #14
bowtie1
Can anyone tell me what the hole is on the left above the frost plug?
Chris
bowtie1 is offline   Reply With Quote
Old 02-21-2011, 02:10:39 AM   #15
70sbudget
Originally Posted by theflash
AWESOME! this hole is open and unpluged. the one over the oil filter is pluged. thus, this is the new location for me. next question. the oil pressure sending unit on MINE is HUGE!!!!!! it will stick out from the block by 2 to 3 inches. what system are you guys using where a hose leaves the hole in the block? does the braided hose plug directly into the back of the gauge???
