Old 07-13-2005, 08:28:00 AM   #1
tom3
Synthetic gear lube and leaking seals
Put Mobil 1 in both Camaro rear ends last summer, a 70 and an 88. While the cover was off I pulled the axles and put in new axle seals then. Had to replace the pinion seal in the 88 last month, replaced both axle seals in the 70 yesterday and the pinion seal is leaking a little too, and I just looked at the 88 and there's drop of oil on the backing plate, it's leaking already too at the axle. Have to figure this lube is probably not worth the trouble, time, and money. Figure I've spend about a hundred bucks on lube, seals, and cover gaskets. Hate to just drain it out and put regular lube in but that's looking like the way to go.
tom3 is offline   Reply With Quote
Old 07-13-2005, 09:24:00 AM   #2
COPO's Avatar
The pinion leak could be getting by the groove that the pinion seal made from the drive shaft turning after so many years. You can buy a plastic sleeve for the pinion. I know other guys that are using synthetic gear oil but I don't think I would. It's like the Muncie tranny. Your not really suppose to use GM syncomesh trans fluid on Muncies because it's thinner than 80w90 gear oil. GM syncomesh trans fluid should only be used on late models after the Muncie. The Muncie needs 80w90 gear oil.
I'd be dumping the syn gear oil back in the container and use it for oiling. You need to refill with 80w90 non syn oil. Sounds like the oil is too thin and too slippery.
Mark D
1970 Z28
http://http://ca.geocities.com/mlvd@rogers.com/
WTB: 70 SS396 Chevelle 4-spd, flapper hood car, no rag tops, 1-2 owner car.
Mark My 70 Z28 Web Site http://www.nastyz28.com/~copo/index.htm
Twitter
Qjet rebuilt etc http://www.nastyz28.com/~copo/qjet.zip
Old 07-13-2005, 09:36:00 AM   #3
Gary S
I have been running Amsoil 75w90 synthetic gear lube in all my rear ends for almost 20 years with no problems or leaks. I also use in my Muncie 4 speed in my Camaro and also in the clunky Muncie truck 4 speed in my Chevy pickup. This stuff is designed to replace the non-synthetic gear lubes and works just like the original stuff, but you get the advantages of synthetic. The Mobil 1 I've seen isn't a gear lube, and it shouldn't be used as a gear lube.
Gary S is offline   Reply With Quote
Old 07-13-2005, 02:39:00 PM   #4
tom3
Bottle says GL5 for hypoid differentials and manual transmissions, but if I see one more drop of oil, I'll be takng COPO's advice. Almost nine bucks a quart for nothing but trouble. The Amsoil might be a better product but it's nowhere around here.
Old 07-13-2005, 10:40:00 PM   #5
big gear head
Are you using sealant around the outside of the seals before you drive them in? Are you putting some grease or oil on the rubber lip of the seal before you put it back together? Did you put some sealant in the splines inside the yoke before you put it back on? There are lots of reasons that seals leak. I have never seen one leak because of synthetic oil. I have been using Amsoil in all of my cars and trucks for over 8 years now with no leaks caused by the oil.
Byars Performance LLC
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
big gear head is offline   Reply With Quote
Old 07-14-2005, 09:11:00 PM   #6
tgw323
I had trouble with Red LIne leaking at the pinion seal. Just a little bit of auto trans sealer seemed to take care of it.
tgw323 is offline   Reply With Quote
Old 07-17-2005, 11:02:00 AM   #7
GoldenOne7710
For the record. Synthetic libricants of ANY form or fashion DO NOT CAUSE LEAKS. However, if you use sythetics in stuff where there are ALREADY leaks, yes it will leak faster. This is only because of the greater flow characteristics of sythetics. So if you have a leak period. Fix it. It done right, the leak WILL NOT come back any time soon. Not pointing fingers at anyone specific by the way. Just trying to educate.
Objects In Mirror Are LOSING
-Andy
1979 Z/28 (better than cloned)
ΜOΛΩΝ ΛΑΒE
Proud NRA Lifetime Member
GeorgiaCarry.org Member
GeorgiaPacking.org Member
GoldenOne7710 is offline   Reply With Quote
Old 07-18-2005, 10:15:00 PM   #8
BonzoHansen
LGM, Admin
BonzoHansen's Avatar
<font face="Arial,Verdana" size="2">Originally posted by GoldenOne7710:
</font>
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Originally Posted by big gear head
Just remember, if you can't afford to do it right the first time then you can't afford to fix it the second time.
Where's that confounded bridge?
BonzoHansen is offline   Reply With Quote
